> 3sgte help. coolant temp, while under boost.
post Mar 9, 2006 - 2:02 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
so im out driving my celica around. and any time i boost the coolant temp guage rapidly goes up. so i stop boosting and then it goes down. full coolant wasnt low.
ok the sensor thats in the top right hand corner the one you cant see in the pic has nothing connected to that wire no place to hook it up to. could that be the problem. if so which i think it must. what do i do. am i missing where that plugs into?
- x_itchy_b_x   3sgte help. coolant temp   Mar 9, 2006 - 2:02 PM
- - lagos   from top to bottom you have, oil presure, cold sta...   Mar 9, 2006 - 2:09 PM
- - x_itchy_b_x   this on. nah i fixed the Cold start one. some jb w...   Mar 9, 2006 - 2:15 PM
|- - Dr_Tweak   QUOTE(x_itchy_b_x @ Mar 9, 2006 - 7...   Mar 9, 2006 - 7:36 PM
- - lagos   yeah i THINK thats the one that goes to the gauge....   Mar 9, 2006 - 2:28 PM
- - x_itchy_b_x   well my guages work so if it isnt hooked up then i...   Mar 9, 2006 - 2:38 PM
- - jgreening   What are you using for a radiator?   Mar 9, 2006 - 3:05 PM
- - lagos   it could be that you are overheating. you did re...   Mar 9, 2006 - 4:41 PM
- - x_itchy_b_x   nah. i havent replaced it. we are flushing the coo...   Mar 9, 2006 - 5:22 PM
- - lagos   yeah, it could be a headgasket do a compression ...   Mar 9, 2006 - 5:23 PM
- - x_itchy_b_x   we drained and flushed and bled the air out and no...   Mar 9, 2006 - 6:16 PM
- - lagos   QUOTE(x_itchy_b_x @ Mar 9, 2006 - 6...   Mar 9, 2006 - 7:14 PM
- - DG_Performance   sounded like an air pocket to me... easy sign for...   Mar 9, 2006 - 7:23 PM
- - lagos   here u go   Mar 9, 2006 - 7:40 PM
- - Dr_Tweak   Also John, if it happens again, take your radiator...   Mar 9, 2006 - 7:48 PM
- - x_itchy_b_x   sweet thanks guys. yeah t seems to be fine now. ti...   Mar 9, 2006 - 7:54 PM
- - x_itchy_b_x   noooo. well. the coolant keeps disapearing and whe...   Mar 10, 2006 - 2:07 PM
- - lagos   that sucks. i guess thats what we get for buyi...   Mar 10, 2006 - 2:11 PM
- - x_itchy_b_x   well. i plan to buy any 2mm head gasket. metal ofc...   Mar 10, 2006 - 2:20 PM
- - scothaniel   Do yourself a favor and get a real water temp gaug...   Mar 10, 2006 - 3:57 PM
- - Dr_Tweak   John, I was afraid of that I have a set of head...   Mar 10, 2006 - 5:34 PM
Lo-Fi Version Time is now: August 4th, 2026 - 11:56 AM
