> TRANSGO A245E-HD2 HIGH PERFORMANCE SHIFT KIT TOYOTA, This sounds too good to be true.
post Mar 11, 2006 - 1:24 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...%3AAAQ%3AUS%3A1
Hello,
These kits have a few different spings, drill bits, & other micsellaneous parts that go in the valve body. This comes with 11 pages of instructions to make all of the modifications. All changes are just inside the pan, so it doesn't need to be out.
Thanks,
Hello, I'm new here and I have a 1993 Geo Prizm 7A-FE with the A245E transmission. I haven't found any good iinformation about that shift kit and someone suggested that I try asking about it here since I do have the same drivetrain as the '94 Celica and possibly some '95 Celicas. Does anyone here know anything about it or have any opinions?
This summer I am due to drop my trans pan and clean the filter/magnets and check the clutch packs and bands, I plan on doing this along with the 120K timing belt and putting on a new waterpump (I'm not sure how long they typically last on the 7a-fe but better safe than sorry I would think).
post Mar 12, 2006 - 2:59 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Welcome, some may flame you for posting w/o a Celica, but hey, at least you got the same engine as the ST. The 7A Celicas use a C52 transmission, but same 7AFE, and it is the same in all ST's be it a 94 or a 97 (didn't they stop making ST's in 98?). If this "Shifter Kit" is the real deal, then I would say try it, but with the price as low as it is, I wouldn't do it. If your transmission is slipping and getting ready to die, why not just replace it with another one like it.
If you want to try it, then do so, but I wouldn't trust myself doing anything like that. Thank god I have a Manual. tongue.gif
**** Photobucket
post Mar 12, 2006 - 3:10 AM
i wouldnt buy it without finding out what it really is, and how its installed.
post Mar 12, 2006 - 11:46 AM
Bitter
Joined Mar 11, '06
well when i emailed the seller asking more about it gave me the little snippet quoted below the ebay link.
it SEEMS to be some stiffer springs and larger passages to allow fluid to flow faster/in more volume and the springs to close the hydrolics faster.
my knowledge about the inner workings of the automatic is somewhat limited but with my GF's help (shes taken auto trans class, i havent yet) i could probably do the install. im just wary because thats a cheap price and the parts im messing with arent as cheap, nor is a new trans if something breaks off and grinds up into the fluid and ruins some bearings.
im pretty sure the automatic ST has the same transaxle that i do, the C52 is a 5spd toyota transaxle shared with the mr-2 and probably a few other toyotas.
post Mar 12, 2006 - 1:44 PM
it sounds like some type of scam, where they will sell you a little restrictor or something from a hardware store for 100bucks.
contact the seller...ask for pics of the actual product you are getting, exactly how it works and how its installed. if it sounds to good to be true......
post Mar 12, 2006 - 6:36 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
This isn't really a shift kit in the normal sense. It's just instructions, tools. and stiffer springs to modify your valve body.
Read up here:
http://www.importperformancetrans.com/toyotaauto.shtml#main
and here:
http://www.importperformancetrans.com/inve...55.356167808665
This post has been edited by WannabeGT4: Mar 13, 2006 - 8:23 AM
post Mar 12, 2006 - 8:59 PM
Bitter
Joined Mar 11, '06
QUOTE(WannabeGT4 @ Mar 12, 2006 - 6:36 PM) [snapback]406648[/snapback]
Read up here:
and here:
thanks, but im not sure what im reading in those links? the 2nd one doesnt load properly.
i'll email the seller again for pictures of the product, i couldnt find any anywhere.
also, thanks for helping out a non celica owner. even tho i dont own one i've always been a fan of them, i feel a little bad for the ST owners, my car is about as quick as a stock ST frown.gif
post Mar 13, 2006 - 8:25 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
OK try the link again. It should work now. Sorry 'bout that. In the event that it doesn't work here it is quoted:
QUOTE(IPT @ Mar 13, 2006)
The fact is that there is no shift kit available for most Toyota transmissions! We are able to modify your existing valve body for high performance operation. These are the same modifications that are included in our line of performance transmissions. Experience the change from mild to wild! Please note that this is a modification service- you must ship your valve body to: IPT 1105 Route 23 South Wayne, NJ 07470 Normal turnaround time is 24-48 hours at our shop.
This post has been edited by WannabeGT4: Mar 13, 2006 - 8:29 AM
post Mar 13, 2006 - 11:47 AM
Bitter
Joined Mar 11, '06
yea, the "kit" on ebay sounds like i'm modifying the valve body and changing some springs in some solenoids.
im starting to lean towards lagos on this, that its just $50 drill bit and a $58 book of directions. :lol:
post Mar 14, 2006 - 4:08 PM
Bitter
Joined Mar 11, '06
yea, im not paying $108 for that...
Lo-Fi Version Time is now: August 31st, 2026 - 5:36 AM
