Mar 11, 2006 - 5:36 PM
Enthusiast ![]() Joined Jan 31, '03 From Montreal, Canada Currently Offline Reputation: 1 (100%) |
I put 20$ of premium gas (93 octane) as usual and had my car washed at Shell.
I drive for 15 mins... stop the car for about 45 min and after when i start it again the engine is rattling like crazy and theres white smoke coming out of the muffler. The idle is very low (below 500), the engine shakes alot, smells gas alot. No apparent leaks. Fortunately, I was able to drive the car to the mechanic shop 2 corners away but ill have to wait till monday to know whats the problem. I think the water jets under the car at the car wash might have shot some water in my gas tank cuz there is some rust spots around. What do you think? |
liquor help - white smoke Mar 11, 2006 - 5:36 PM
toyotacrazy Hello, sounds like a blown head gasket. Hows the... Mar 11, 2006 - 5:57 PM
liquor QUOTE(toyotacrazy @ Mar 11, 2006 - 3... Mar 11, 2006 - 7:00 PM
SlowCelica94 Check the coolant overflow and see if it looks/ sm... Mar 11, 2006 - 7:33 PM
liquor QUOTE(SlowCelica94 @ Mar 11, 2006 - 5... Mar 12, 2006 - 6:08 PM
bindertch If you are getting fuel all the way to the ground ... Mar 12, 2006 - 6:31 PM
Bitter it could be an injector (or multiple) injectors st... Mar 12, 2006 - 9:29 PM
liquor Thank you guys - tomorrow the car will be checked ... Mar 12, 2006 - 9:35 PM
liquor Ok the garage just called - they have absolutely n... Mar 13, 2006 - 1:15 PM
Bitter did you ask him to check that each cylinder has sp... Mar 13, 2006 - 2:32 PM
CheesyLobster dude, sounds like you should bring it to another m... Mar 13, 2006 - 4:55 PM
liquor QUOTE(CheesyLobster @ Mar 13, 2006 - 2... Mar 13, 2006 - 6:15 PM
liquor Just got my car back from Toyota and back on the r... Mar 14, 2006 - 9:38 PM
Bitter just like i thought, open injectors
im glad you ... Mar 14, 2006 - 10:05 PM
Ronnie5 QUOTE(liquor @ Mar 11, 2006 - 10:36 ... Mar 15, 2006 - 8:43 AM
liquor QUOTE(Ronnie5 @ Mar 15, 2006 - 6:43 ... Mar 15, 2006 - 11:01 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 8:00 PM |
