Mar 12, 2006 - 12:02 AM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
Today i started to really install the turbo. took the front bumber
off the radiator and the stock exhaust mani spent like half the day on one bolt- striped it -drilled it- broke it. my turbo exhaust mani is very diffearnt from NIK's old 7afte i also had to cut the top left hand side of the mani. the down pipe has to go between two refrigerant lines they are really close i was thinking ...i drain the refrigerant then with a torch heat up the line and bend it a little. how much dose it cost to get it filled? |
Mar 12, 2006 - 7:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I'm not sure what you mean, take some pics.
-Doc This post has been edited by Dr_Tweak: Mar 12, 2006 - 7:14 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Mar 13, 2006 - 3:05 AM
i'll post some pics later
i had to kill my A/C today i tryed to mate the turbo to the mani broke one bolt, drilled through and put another in. made a gasket because after puting it together i could slip a thin pease of paper between the mani and turbo..(somebody told me this would happen). ran inlet oil line and outlet. no restrictor...? ideling at about 60 psi. i put on of those flex exhust pipes going stright down in for now. Turned on the car today turbo started to spin nicely something dosn't sound right? ....i'm tired pics + vid soon |
Mar 13, 2006 - 4:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
With 60 psi at idle, use the restrictor. some smoke is normal on first startup, but not a lot. Hope you can get that AC back up, its nice to have. sounds good though, lets get some pics!
Mar 13, 2006 - 5:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
we need some pics so we can help
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Mar 13, 2006 - 11:18 PM
i'm in at my parents house .. no cam..sister should get hers back tomarrow.
today i tryed to get the down pipe welded i took them the downpipe piece with the autozone flex pipe thing on it they said bring in the car so i drove it with the flex pipe just going stright down LOUD they wanted 90$ just to do the downpipe .**** that right.. ..:)even with stright pipe you can still hear the turbo spining up LOUD??i'm new to this sound ME LIKES.. so right now i have some low impedance injectors so what resisters do i need from radio shack to make them work????????----MAIN QUESTION OF THE DAY---if some body can give me a part number...I would be very thankful..10watt 10ohm ?? also what wire do i connect them to? so i'ma go try to find a cheaper place tomarrow for the downpipe.... i should also have some pictures This post has been edited by southwest2118: Mar 14, 2006 - 2:41 AM |
Mar 15, 2006 - 7:25 PM
haha, not electrical restrictor; its a piping restrictor that goes on your oil line. go to:
http://www.jgstools.com/turbo/index2.html click on turbo accessories and adapters. buy: 0.063" Oil Pressure Orifice 303 SS, 1/8" male to 1/8" female NPT, use thread sealant on all NPT connections. $15 This post has been edited by CheesyLobster: Mar 15, 2006 - 7:28 PM |
Mar 15, 2006 - 11:09 PM
QUOTE(CheesyLobster @ Mar 15, 2006 - 6:25 PM) [snapback]408178[/snapback] haha, not electrical restrictor; its a piping restrictor that goes on your oil line. go to: http://www.jgstools.com/turbo/index2.html click on turbo accessories and adapters. buy: 0.063" Oil Pressure Orifice 303 SS, 1/8" male to 1/8" female NPT, use thread sealant on all NPT connections. $15 I have the oil restrictor from atp..just don't use it right now. No I'm not talking about that cheesy i ran 10w 10ohm inline with my low impedance injectors to make them high so right now they are like 13ohm works great... but today i got my downpipe done WOW they did a nice job looks clean but i didn't get the muffler put in. so it's a "sleeper" for now but they forgot to put that up stream o2 sensor. |
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:12 PM |
