Mar 13, 2006 - 5:19 PM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
Hi
Tried searching but too many thread on teins and can't find any information. Just got Teins installed in my car by a shop. Everything is great and handles awesome but I have a small problem. When I go over bumps, I get a clunk sound from the fronts. Sounds as though the springs are not sitting properly ... THis only happens when I go over bumps, no sound when accelerating etc. Shop advised me to go back to them and they will take a look but do you guys have any ideas? Front shocks are fine. Back shocks are new kybs . Couldnt change the front shocks because I had the sealed units |
Mar 13, 2006 - 6:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
i have the sam eproblem.....my problem was jus a faulty shock mount....i havent installed mines yet but i can tell u its jus that/./..the mechanic told me ull hear a clunkin sound at first for the spring to sit properly..but later on if u still hear soound comin from the front it will be your shock mounts..hope this help
Mar 13, 2006 - 6:42 PM
Enthusiast ![]() Joined Jan 31, '03 From Montreal, Canada Currently Offline Reputation: 1 (100%) |
QUOTE(DeW_H0e_GT @ Mar 13, 2006 - 4:39 PM) [snapback]407094[/snapback] i have the sam eproblem.....my problem was jus a faulty shock mount....i havent installed mines yet but i can tell u its jus that/./..the mechanic told me ull hear a clunkin sound at first for the spring to sit properly..but later on if u still hear soound comin from the front it will be your shock mounts..hope this help I have my Teins installed 2 years ago and still very nice - once had your problem at the back but the shock mounts should solve your problem... |
Mar 14, 2006 - 2:16 AM
Will try it for a few more days and see what happens
certainly sounds as though the spring is not sitting properly. edit./ went out for drive over quite a few speed bumps. clunking only comes from front left shock so definitely something wrong there. going back to shop tomorrow. This post has been edited by soven: Mar 14, 2006 - 3:37 AM |
Mar 14, 2006 - 4:21 PM
QUOTE(soven @ Mar 14, 2006 - 2:16 AM) [snapback]407320[/snapback] Will try it for a few more days and see what happens certainly sounds as though the spring is not sitting properly. edit./ went out for drive over quite a few speed bumps. clunking only comes from front left shock so definitely something wrong there. going back to shop tomorrow. same thign im havin right now -------------------- ![]() |
Mar 14, 2006 - 5:47 PM
check your struts and make sure you didnt blow any of them as well.
Mar 15, 2006 - 1:22 AM
Went back to the shop. jacked each side up. Tried moving the springs but they were captive and not move-able which was good. However, the springs were looser on the left side which is the side that is having the problems.
Shop person came to the conclusion that the front shock is on the way out.... Reasoning was the noise only appeared on large bumps, not on corners or normal driving. Therefore it isnt something lose. He mentioned something about the springs "just" sitting there(captive) or something. I thought the teins wouldnt have been a problem with its 1.5inch drop. The stupid thing is, The kyb dealer here says that he does not have the celica sealed struts even though I gave him the right part numbers. I will continue to search for it or worse come to worse, find another celica with the normal struts and use that. |
Mar 15, 2006 - 11:36 AM
i am the suspension king! w00t
Mar 15, 2006 - 2:36 PM
QUOTE(LewFX @ Mar 15, 2006 - 11:36 AM) [snapback]407937[/snapback] i am the suspension king! w00t -------------------- ![]() |
Mar 15, 2006 - 2:47 PM
Soven, if you have sealed strut housings, look in junkyards for non-sealed and put in new insert or get another sealed strut. for non-sealed housing, theres a bilstein housing on ebay for 72 bucks then get an insert.
Mar 16, 2006 - 1:31 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
i got the same problem too. but it also makes noises when im turning. but it might be my brake pads cuz the 2 springs between the 2 caliper i lost it. my tanabe is drop 2" in front and 1.5" in the back. it was fine when i first had it on, but then it starts making the noise over bumps.
-------------------- <--- I miss :'' ( |
| Lo-Fi Version | Time is now: May 20th, 2026 - 8:59 AM |
