Mar 13, 2006 - 9:06 PM
Enthusiast ![]() ![]() Joined Dec 22, '04 From O'fallon, MO Currently Offline Reputation: 1 (100%) |
so im driving along..and the engine was making a knocking/ticking type of sound which i've never heard before...so i started takin it slow and everything...then im gettin off the hwy..and the car dies...i try startin it and it starts up knocks alot shaking the whole car and dies again..what do you think is wrong w/the engine? im thinkin a rod or piston or something..but not sure..i bet it could be alot?
Mar 13, 2006 - 9:25 PM
it could be a number of internal problems.
how was your oil level? -------------------- |
Mar 13, 2006 - 9:27 PM
oil was a lil low..but nothin of great concern..so idk
Mar 13, 2006 - 9:35 PM
were you turning or in a long sweeping bend or an on/off ramp?
its *possible* (i dont know the 5sfe oil pan) that if you were on a long sweeper and low on oil that you sucked some air into the oiling system and that spun a bearing. in general how do you treat the car? do you drive it hard often? do you let it warm up for atleast a couple minutes before taking off? its also possible that you spun a bearing or seized/broke a rod out of the blue....but thats less likely. exactly how low were you? -------------------- |
Mar 13, 2006 - 9:42 PM
well..i was on the hwy..and then i was gettin on the off ramp and the car died..generally..i do both type of driving habits..sometimes i drive normal..sometimes hard...as of oil level..it was..i'd say a lil less than the halfway mark...which isnt horrible
Mar 13, 2006 - 9:48 PM
less than the halfway mark is pretty bad!
Mar 13, 2006 - 9:55 PM
eh..it still had enough to run..my oil light wasnt on..and the day b4 everything was running perfectly..it was quite out of the blue
This post has been edited by hockeyplyr24: Mar 13, 2006 - 9:55 PM |
Mar 13, 2006 - 10:01 PM
QUOTE(Bitter @ Mar 13, 2006 - 9:48 PM) [snapback]407190[/snapback] less than the halfway mark is pretty bad! im saying this again so you understand. less than 1/2 is BAD. and one more time less than 1/2 is BAD. it sounds like you spun a bearing (initial sound) then when you kept driving on it seized the rod to the crank and threw the rod making your engine now a 3cylinder or a giant paper weight. -------------------- |
Mar 13, 2006 - 10:12 PM
yea..im pretty upset about it..i couldnt believe what had happened..not much i can really do now i guess..i was plannin on doing a 3sgte swap w/in the next couple months..now i guess i will just have to do it sooner or something....bc im sure this could get quite expensive to fix
Mar 13, 2006 - 11:05 PM
how many miles on the motor?
Mar 14, 2006 - 12:04 AM
i have roughly 165,000 miles on it..which is quite alot
Mar 14, 2006 - 1:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 14, '03 From Jacksonville, FL Currently Offline Reputation: 2 (100%) |
Eh.. that's what happened when I threw a rod.. I got my engine rebuilt since then.
Mar 14, 2006 - 2:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
same thing happened to me...worst day of my life december 8 2003. you threw a rod as stated earlier. and if you think your oil light was gonna come on yer wrong....mine didnt...
Mar 14, 2006 - 4:16 PM
yea i kinda figured thats what happened..im still gonna check everything out first..and maybe bring it by some1 to be sure its not a cheap fix...but other than that im still in search for a st205 and tranny for cheap..i'll look up that place u mentioned..thanks
| Lo-Fi Version | Time is now: June 26th, 2026 - 9:50 AM |
