Mar 14, 2006 - 2:46 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
i passed everything with flying colors except something labeled NO(PPM). it measured at 1115 when the max was 467. this was for the 15 mph test. it passed the 25 mph test reading only 55 out of a maximum 754.
here's the rest of the readings 15 mph hc(ppm) max/meas 61/15 pass co(%) .54/.00 pass no(ppm) 467/1115 failed 25 mph hc(ppm) 45/14 pass co(%) .53/.09 pass no(ppm) 754/55 pass anyone know any info about this? i have a safc2 but everything is zero'd out for the time being since my turbo is out. is there a setting i can use to fix this?? im bringing it in tomorrow to get it looked at and fixed. visual inspection and functional check passed as well. -------------------- ![]() |
forkee got a smog check Mar 14, 2006 - 2:46 AM
Chanh55 I think I had the same problem.. changed the egr a... Mar 14, 2006 - 2:49 AM
forkee u changed it or the shop? estimated cost of repair... Mar 14, 2006 - 2:55 AM
Galcobar According to a catalytic converter manufacturer, w... Mar 14, 2006 - 3:00 AM
Chanh55 They changed it... I had no way of diagnosing that... Mar 14, 2006 - 3:00 AM
forkee awesome info, thanks guys Mar 14, 2006 - 3:41 AM
Hanyo this is with the turbo out, but are you using larg... Mar 14, 2006 - 3:43 AM
forkee stock injectors but walbro fuel pump Mar 14, 2006 - 9:20 AM
Bitter thats a NOX failure caused by either an egr valve ... Mar 14, 2006 - 1:35 PM
sugarfree My engine threw a code last night, and this mornin... Mar 14, 2006 - 2:39 PM
Bitter it is possible the clean an egr valve and restore ... Mar 14, 2006 - 3:24 PM
sugarfree Yea i do run 93 octane. Mar 14, 2006 - 3:51 PM
Bitter QUOTE(sugarfree @ Mar 14, 2006 - 3:5... Mar 14, 2006 - 4:08 PM
sugarfree Nah i just figured it would help idle, but im goin... Mar 14, 2006 - 5:10 PM
Bitter QUOTE(sugarfree @ Mar 14, 2006 - 5:1... Mar 14, 2006 - 9:30 PM
forkee Well I brought it to the dealer. They said its bey... Mar 15, 2006 - 3:11 PM
Bitter QUOTE(forkee @ Mar 15, 2006 - 3:11 P... Mar 15, 2006 - 4:22 PM
sugarfree I just cleaned mine today, 45mins and a new gasket... Mar 15, 2006 - 4:20 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 16th, 2026 - 3:19 AM |
