> Broken Locks - Newbie member, Need to replace/fix locks
post Mar 14, 2006 - 9:52 PM
Celicatime
Joined Feb 4, '06
From washdc
I am a newbie so go easy on me. I just bought a 94 GT and the driver side lock does not work. Lock partially turns but won't unlock door. ToyotaWorld has the lock cylinders for $37. Is that the cheapest I can get? I assume I have to change all 3 locks plus ignition if I w frown.gif ant one key? Searched for this answer but couldn't find it.
94 CelicaGT producing massive amonts of NOx - UGH!!!
98 Volvo V70 - guzzling lots of gas - GAAH!
post Mar 14, 2006 - 9:54 PM
spke719
Joined Dec 31, '04
From white hall, Maryland
did u tear ur door apart and see what the problem is??? go that route first. it is the cheapest. plus ur getting into alot more work changing all ur locks.
This post has been edited by spke719: Mar 14, 2006 - 9:56 PM
[font=Comic Sans Ms][size=3]
SI VIS PACEM PARA BELLUM (if you wish for peace, prepare for war!)
post Mar 14, 2006 - 10:00 PM
Celicatime
Joined Feb 4, '06
From washdc
Guess I could do that. Wondering if I'll just find a cylinder that doesn't turn.
Is that silver trim in your profile pics painted or is it a kit?
post Mar 20, 2006 - 5:37 PM
spke719
Joined Dec 31, '04
QUOTE(Celicatime @ Mar 14, 2006 - 10:00 PM) [snapback]407715[/snapback]
it was a kit but i took it all out now...gonna do somethin diff
post Mar 20, 2006 - 6:24 PM
DeathWing
Joined Feb 10, '06
From Chile
not long ago my passanger door didnt open from the outside, instead of opening the door with the lock off, it locked the door, problem solved with WD40 or whatever you want to use when metals dont slide, dont be afraid, disarm the door tongue.gif
This post has been edited by DeathWing: Mar 20, 2006 - 6:24 PM
post Mar 20, 2006 - 8:03 PM
Celicatime
Joined Feb 4, '06
From washdc
QUOTE(DeathWing @ Mar 20, 2006 - 6:24 PM) [snapback]410618[/snapback]
I took the door apart and tried to spray the life out of all the moving parts with WD40 - No luck - it will unlock with the power door switch, but not with the key. Have you ever tried to get to these lock mechanisms - you have to take every single thing off the freakin door and it's still mostly hidden behind the door frame - STUPIFYING mad.gif !
I also think I have a Toyota remote key system installed, but I don't have the remote - is it easy to get one to match what's in my car?
post Mar 20, 2006 - 8:10 PM
97lestyousay
Joined Jul 7, '03
I don't know if he still has them but here you go.
http://www.6gc.net/forums/index.php?showtopic=35034
JDM guy made me do it.
post Mar 20, 2006 - 8:42 PM
Celicatime
Joined Feb 4, '06
From washdc
Thx. I'll find out.
post Mar 21, 2006 - 4:51 AM
Yellow94GT
Joined Mar 17, '06
QUOTE(Celicatime @ Mar 14, 2006 - 9:52 PM) [snapback]407702[/snapback]
My 94 GT drivers side door lock was stuck last spring. I went inside the door. Wow. There is alot of stuff inside and the lock is not easy to get at! I got a quote from a local locksmith who gave me a quote for 45$ to get the parts (not including the labor) for another lock cylinder that would work with my existing key.
Turns out that mine was frozen and loosened with the right spray. It still seems very worn and sticks a little sometimes.
Yellow94Gt
post Mar 21, 2006 - 7:55 PM
Celicatime
Joined Feb 4, '06
From washdc
QUOTE(Yellow94GT @ Mar 21, 2006 - 4:51 AM) [snapback]410860[/snapback]
Yellow94Gt
Glad I'm not the only one who finds getting at these locks difficult
post Mar 22, 2006 - 12:00 AM
getting to the locks in the doors isn't too hard at all. Once you get the door panel off use this link, then just unbolt the handle (2 10mm bolts) and unclip the "U" or "C" shaped clips holding the rods in place at the inside of the handle (2 rods, one for opening the door, the other for lock/unlock the door). Once the handles are out, you can replace the lock cylinders easliy.
Lo-Fi Version Time is now: September 17th, 2026 - 8:55 AM
