Mar 15, 2006 - 1:50 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
We just completed swapping her all the hoses and stuff are connected.... I think..
This is from a 6gc with a completed swap... I did a auto to manual swap, does it matter if I connect the park neutral thing in order to start the car? If so... where is that wire at? When I turn the key, everything sounds normal... but the starter doesn't turn over... Please help... I'm thinking it's something with the wiring. I'm stumped. This post has been edited by Chanh55: Mar 22, 2006 - 5:23 PM |
Chanh55 Help Update: Speedo Still Not Working Mar 15, 2006 - 1:50 AM
lagos you need to wire in, or bypass the clutch start sw... Mar 15, 2006 - 1:57 AM
Chanh55 Do you know where that is? I can't find it. Mar 15, 2006 - 2:10 AM
Consynx follow the started to the ignition? Mar 15, 2006 - 2:19 AM
Chanh55 Eggman... Lagos.... Doc... Help! ahhh Mar 15, 2006 - 3:06 AM
WannabeGT4 Check fuses "60A MAIN", "30A AM2... Mar 15, 2006 - 12:16 PM
x_itchy_b_x ok check this also (this was my promblem)
where th... Mar 15, 2006 - 12:22 PM
Chanh55 QUOTE(x_itchy_b_x @ Mar 15, 2006 - 9... Mar 15, 2006 - 1:43 PM
Rjb23 QUOTE(Chanh55 @ Mar 15, 2006 - 6:43 ... Mar 15, 2006 - 1:59 PM
WannabeGT4 QUOTE(Chanh55 @ Mar 15, 2006 - 12:43... Mar 15, 2006 - 2:04 PM
x_itchy_b_x anything yet? Mar 15, 2006 - 1:24 PM
Chanh55 RIB, can you do me a huge favor and take pic of wh... Mar 15, 2006 - 2:12 PM
Chanh55 I got the fuse out... wtf it's bolted down fro... Mar 15, 2006 - 2:56 PM
Rjb23 Chanh, I can look later and tell you. But the Circ... Mar 15, 2006 - 4:14 PM
Chanh55 Hey RJB... I'm gonna need a pic of how that wa... Mar 15, 2006 - 5:10 PM
Rjb23 I'll see what I can do. What you want to do is... Mar 15, 2006 - 5:47 PM
DG_Performance I am still not following your problem?
does the ca... Mar 15, 2006 - 7:19 PM
Rjb23 Sorry I couldn't get a good enough picture to ... Mar 16, 2006 - 1:05 PM
Chanh55 QUOTE(Rjb23 @ Mar 16, 2006 - 10:05 A... Mar 16, 2006 - 1:59 PM
tomazws I don't think I'm any help lol, but I hope... Mar 16, 2006 - 2:13 PM
Dr_Tweak Chan, give me a call if you like. 802-334-6553.
-... Mar 16, 2006 - 2:21 PM
WannabeGT4 There is a less complicated way to accomplish the ... Mar 16, 2006 - 2:43 PM
Rjb23 I don't think there is a black and black yello... Mar 16, 2006 - 3:09 PM
WannabeGT4 Wirings diagrams for both the 90-91 and 92-93 3SGT... Mar 16, 2006 - 3:12 PM
Rjb23 Yea me too but if I remember right I didn't ha... Mar 16, 2006 - 3:15 PM
WannabeGT4 Auto and Manual COR wiring should be the same... e... Mar 16, 2006 - 3:31 PM
Chanh55 I gave doc a call, I will give his suggestion a tr... Mar 16, 2006 - 5:44 PM
Chanh55 Bump, please see page 1. Mar 16, 2006 - 11:08 PM
WannabeGT4 QUOTE(Rjb23 @ Mar 16, 2006 - 2:15 PM... Mar 17, 2006 - 12:09 PM
Dr_Tweak Yes, but the black wire goes to a different place ... Mar 17, 2006 - 6:22 PM
WannabeGT4 QUOTE(Dr_Tweak @ Mar 17, 2006 - 5:22... Mar 18, 2006 - 7:06 PM
Chanh55 My speedometer isn't working. I checked all th... Mar 20, 2006 - 5:35 PM
Dr_Tweak Here you go Chan:
That's what we talked abo... Mar 20, 2006 - 10:25 PM
DG_Performance The easy way to do it.... i am guessing you will n... Mar 21, 2006 - 1:14 AM
Chanh55 QUOTE(DG_Performance @ Mar 20, 2006 - 10... Mar 21, 2006 - 1:16 AM
DG_Performance You can kiss me later....
NOT!
II1 is one of t... Mar 21, 2006 - 1:17 AM
Chanh55 QUOTE(DG_Performance @ Mar 20, 2006 - 10... Mar 21, 2006 - 1:26 AM
madmods Chann, you made this comment on another post:
It... Mar 21, 2006 - 6:50 PM
Chanh55 Well...
1. I drove to the mufflerr shop with a b... Mar 21, 2006 - 7:05 PM
madmods QUOTE(Chanh55 @ Mar 22, 2006 - 12:05... Mar 22, 2006 - 12:45 AM
Chanh55 I haven't really pushed her yet... but when I ... Mar 22, 2006 - 12:59 AM
Chanh55 Speedometer still not working.
Can someone give ... Mar 22, 2006 - 4:14 PM
Chanh55 I've pushed her... and to answer your question... Mar 22, 2006 - 6:32 PM
95celgt bump!, trying to fix speed sensor!, idles ... Apr 17, 2006 - 12:34 AM
lagos are you the new owner or something?
you should b... Apr 17, 2006 - 1:00 AM
95celgt i replaced them with iridiums because thats what w... Apr 17, 2006 - 10:25 AM
playr158 the iridium tip is too small for turbo cars really... Apr 17, 2006 - 10:57 AM
95celgt i just read that the iriduim plugs(IK20) come pre-... Apr 17, 2006 - 10:59 AM
WannabeGT4 Might as well give it a try. It can't hurt.
A... Apr 17, 2006 - 11:20 AM
95celgt yea, but damn, even now it runs awesome aside from... Apr 17, 2006 - 11:23 AM
Chanh55 Pictures! Apr 17, 2006 - 11:40 AM
playr158 NGK BKR6E are very easy to find at nearly any auto... Apr 17, 2006 - 1:54 PM
95celgt well i fixed the misfiring, a wire that goes to th... Apr 17, 2006 - 5:05 PM
playr158 gap should be
.8mm or .031in Apr 17, 2006 - 6:47 PM
Rjb23 QUOTE(playr158 @ Apr 17, 2006 - 11:4... Apr 25, 2006 - 12:52 PM
95celgt hi guys, i put in normal plugs, started...fan fine... Apr 24, 2006 - 5:53 PM
playr158 how are you advancing your timing and playing with... Apr 24, 2006 - 7:05 PM
95celgt QUOTE(playr158 @ Apr 24, 2006 - 7:05... Apr 24, 2006 - 7:32 PM
lagos QUOTE(95celgt @ Apr 24, 2006 - 8:32 ... Apr 24, 2006 - 9:14 PM
95celgt DAMMIT!!! It runs soooo much better at... Apr 24, 2006 - 10:08 PM
lagos you probably have a boost leak or something
runni... Apr 24, 2006 - 11:33 PM
95celgt QUOTE(lagos @ Apr 24, 2006 - 11:33 P... Apr 25, 2006 - 12:11 AM
LewFX what did you do to the beast??? Apr 24, 2006 - 11:36 PM
95celgt Cool, I noticed the Breather filter attatched to t... Apr 25, 2006 - 10:20 PM
lagos i still dont understand why people use breather fi... Apr 25, 2006 - 10:25 PM
Rjb23 QUOTE(lagos @ Apr 26, 2006 - 3:25 AM... Apr 26, 2006 - 12:53 PM
95celgt it came like that lagos:P
but even then, it shoul... Apr 25, 2006 - 10:31 PM
lagos QUOTE(95celgt @ Apr 25, 2006 - 11:31... Apr 26, 2006 - 3:00 AM
playr158 QUOTE(Rjb23 @ Apr 25, 2006 - 1:52 PM... Apr 26, 2006 - 2:27 PM
lagos QUOTE(Rjb23 @ Apr 26, 2006 - 1:53 PM... Apr 26, 2006 - 2:35 PM
Rjb23 I don't have crappy idle or vac, I run 20 vac ... Apr 26, 2006 - 3:17 PM
playr158 better yet.....get a catch can Apr 26, 2006 - 3:29 PM
Rjb23 QUOTE(playr158 @ Apr 26, 2006 - 8:29... Apr 26, 2006 - 4:11 PM
Doge I would listen to Lagos. Tee off your intake line... Apr 26, 2006 - 6:20 PM
Rjb23 QUOTE(Doge @ Apr 26, 2006 - 11:20 PM... Apr 27, 2006 - 9:44 AM
95celgt The car has become undrivable from all the smoke i... Apr 26, 2006 - 7:14 PM
WannabeGT4 QUOTE(95celgt @ Apr 26, 2006 - 7:14 ... Apr 26, 2006 - 9:31 PM
phattyduck QUOTE(WannabeGT4 @ Apr 26, 2006 - 7... Apr 27, 2006 - 5:16 PM
playr158 QUOTE(WannabeGT4 @ Apr 26, 2006 - 10... Apr 26, 2006 - 9:32 PM
WannabeGT4 Isn't a catch can a whole lot easier in our ca... Apr 26, 2006 - 9:39 PM
lagos or you could just hook it up the way toyota did it... Apr 26, 2006 - 9:40 PM
95celgt LOL @ Lagos
I finished running a hose to the Inta... Apr 26, 2006 - 9:50 PM
Doge The crankcase is not a vacuum... but the intake is... Apr 27, 2006 - 11:30 AM
Rjb23 QUOTE(Doge @ Apr 27, 2006 - 4:30 PM)... Apr 27, 2006 - 3:13 PM
lagos QUOTE(Doge @ Apr 27, 2006 - 12:30 PM... Apr 27, 2006 - 11:40 AM
Doge What's your point? The PCV needs the vacuum o... Apr 27, 2006 - 3:47 PM
lagos QUOTE(Rjb23 @ Apr 27, 2006 - 4:13 PM... Apr 27, 2006 - 4:14 PM
95celgt guys, some help on a problem?
Car runs crappy whe... May 2, 2006 - 10:46 PM
lagos can you tell us what "crappy" means? May 2, 2006 - 11:02 PM
95celgt the extreme case of misfire when I give it throttl... May 2, 2006 - 11:15 PM
lagos did you see what happend to my car on the dyno whe... May 2, 2006 - 11:47 PM
95celgt i put in the ngk's, and it ran crappier than t... May 3, 2006 - 12:27 AM
Consynx i run the 6097's by ngk, iunno what heat range... May 3, 2006 - 12:58 AM
95celgt mine are brk6e?
car misfires INCREDIBLY in vaccum... May 6, 2006 - 5:00 PM
95celgt any ideas? May 10, 2006 - 11:42 AM
lagos have you checked for boost leaks? May 10, 2006 - 11:44 AM
95celgt car runs good for days, some times it runs bad, i ... Jun 30, 2006 - 1:49 AM
95celgt so i got bored today and decided to poke at the wi... Nov 16, 2007 - 12:21 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:38 PM |
