> Help Update: Speedo Still Not Working
post Mar 15, 2006 - 1:50 AM
Chanh55
Joined Jun 29, '03
We just completed swapping her all the hoses and stuff are connected.... I think..
This is from a 6gc with a completed swap...
I did a auto to manual swap, does it matter if I connect the park neutral thing in order to start the car? If so... where is that wire at?
When I turn the key, everything sounds normal... but the starter doesn't turn over...
Please help... I'm thinking it's something with the wiring. I'm stumped.
This post has been edited by Chanh55: Mar 22, 2006 - 5:23 PM
- Chanh55   Help Update: Speedo Still Not Working   Mar 15, 2006 - 1:50 AM
- - lagos   you need to wire in, or bypass the clutch start sw...   Mar 15, 2006 - 1:57 AM
- - Chanh55   Do you know where that is? I can't find it.   Mar 15, 2006 - 2:10 AM
- - Consynx   follow the started to the ignition?   Mar 15, 2006 - 2:19 AM
- - Chanh55   Eggman... Lagos.... Doc... Help! ahhh   Mar 15, 2006 - 3:06 AM
- - WannabeGT4   Check fuses "60A MAIN", "30A AM2...   Mar 15, 2006 - 12:16 PM
- - x_itchy_b_x   ok check this also (this was my promblem) where th...   Mar 15, 2006 - 12:22 PM
|- - Chanh55   QUOTE(x_itchy_b_x @ Mar 15, 2006 - 9...   Mar 15, 2006 - 1:43 PM
|- - Rjb23   QUOTE(Chanh55 @ Mar 15, 2006 - 6:43 ...   Mar 15, 2006 - 1:59 PM
|- - WannabeGT4   QUOTE(Chanh55 @ Mar 15, 2006 - 12:43...   Mar 15, 2006 - 2:04 PM
- - x_itchy_b_x   anything yet?   Mar 15, 2006 - 1:24 PM
- - Chanh55   RIB, can you do me a huge favor and take pic of wh...   Mar 15, 2006 - 2:12 PM
- - Chanh55   I got the fuse out... wtf it's bolted down fro...   Mar 15, 2006 - 2:56 PM
- - Rjb23   Chanh, I can look later and tell you. But the Circ...   Mar 15, 2006 - 4:14 PM
- - Chanh55   Hey RJB... I'm gonna need a pic of how that wa...   Mar 15, 2006 - 5:10 PM
- - Rjb23   I'll see what I can do. What you want to do is...   Mar 15, 2006 - 5:47 PM
- - DG_Performance   I am still not following your problem? does the ca...   Mar 15, 2006 - 7:19 PM
- - Rjb23   Sorry I couldn't get a good enough picture to ...   Mar 16, 2006 - 1:05 PM
|- - Chanh55   QUOTE(Rjb23 @ Mar 16, 2006 - 10:05 A...   Mar 16, 2006 - 1:59 PM
- - tomazws   I don't think I'm any help lol, but I hope...   Mar 16, 2006 - 2:13 PM
- - Dr_Tweak   Chan, give me a call if you like. 802-334-6553. -...   Mar 16, 2006 - 2:21 PM
- - WannabeGT4   There is a less complicated way to accomplish the ...   Mar 16, 2006 - 2:43 PM
- - Rjb23   I don't think there is a black and black yello...   Mar 16, 2006 - 3:09 PM
- - WannabeGT4   Wirings diagrams for both the 90-91 and 92-93 3SGT...   Mar 16, 2006 - 3:12 PM
- - Rjb23   Yea me too but if I remember right I didn't ha...   Mar 16, 2006 - 3:15 PM
- - WannabeGT4   Auto and Manual COR wiring should be the same... e...   Mar 16, 2006 - 3:31 PM
- - Chanh55   I gave doc a call, I will give his suggestion a tr...   Mar 16, 2006 - 5:44 PM
- - Chanh55   Bump, please see page 1.   Mar 16, 2006 - 11:08 PM
- - WannabeGT4   QUOTE(Rjb23 @ Mar 16, 2006 - 2:15 PM...   Mar 17, 2006 - 12:09 PM
- - Dr_Tweak   Yes, but the black wire goes to a different place ...   Mar 17, 2006 - 6:22 PM
|- - WannabeGT4   QUOTE(Dr_Tweak @ Mar 17, 2006 - 5:22...   Mar 18, 2006 - 7:06 PM
- - Chanh55   My speedometer isn't working. I checked all th...   Mar 20, 2006 - 5:35 PM
- - Dr_Tweak   Here you go Chan: That's what we talked abo...   Mar 20, 2006 - 10:25 PM
- - DG_Performance   The easy way to do it.... i am guessing you will n...   Mar 21, 2006 - 1:14 AM
|- - Chanh55   QUOTE(DG_Performance @ Mar 20, 2006 - 10...   Mar 21, 2006 - 1:16 AM
- - DG_Performance   You can kiss me later.... NOT! II1 is one of t...   Mar 21, 2006 - 1:17 AM
|- - Chanh55   QUOTE(DG_Performance @ Mar 20, 2006 - 10...   Mar 21, 2006 - 1:26 AM
- - madmods   Chann, you made this comment on another post: It...   Mar 21, 2006 - 6:50 PM
- - Chanh55   Well... 1. I drove to the mufflerr shop with a b...   Mar 21, 2006 - 7:05 PM
|- - madmods   QUOTE(Chanh55 @ Mar 22, 2006 - 12:05...   Mar 22, 2006 - 12:45 AM
- - Chanh55   I haven't really pushed her yet... but when I ...   Mar 22, 2006 - 12:59 AM
- - Chanh55   Speedometer still not working. Can someone give ...   Mar 22, 2006 - 4:14 PM
- - Chanh55   I've pushed her... and to answer your question...   Mar 22, 2006 - 6:32 PM
- - 95celgt   bump!, trying to fix speed sensor!, idles ...   Apr 17, 2006 - 12:34 AM
- - lagos   are you the new owner or something? you should b...   Apr 17, 2006 - 1:00 AM
- - 95celgt   i replaced them with iridiums because thats what w...   Apr 17, 2006 - 10:25 AM
- - playr158   the iridium tip is too small for turbo cars really...   Apr 17, 2006 - 10:57 AM
- - 95celgt   i just read that the iriduim plugs(IK20) come pre-...   Apr 17, 2006 - 10:59 AM
- - WannabeGT4   Might as well give it a try. It can't hurt. A...   Apr 17, 2006 - 11:20 AM
- - 95celgt   yea, but damn, even now it runs awesome aside from...   Apr 17, 2006 - 11:23 AM
- - Chanh55   Pictures!   Apr 17, 2006 - 11:40 AM
- - playr158   NGK BKR6E are very easy to find at nearly any auto...   Apr 17, 2006 - 1:54 PM
- - 95celgt   well i fixed the misfiring, a wire that goes to th...   Apr 17, 2006 - 5:05 PM
- - playr158   gap should be .8mm or .031in   Apr 17, 2006 - 6:47 PM
|- - Rjb23   QUOTE(playr158 @ Apr 17, 2006 - 11:4...   Apr 25, 2006 - 12:52 PM
- - 95celgt   hi guys, i put in normal plugs, started...fan fine...   Apr 24, 2006 - 5:53 PM
- - playr158   how are you advancing your timing and playing with...   Apr 24, 2006 - 7:05 PM
|- - 95celgt   QUOTE(playr158 @ Apr 24, 2006 - 7:05...   Apr 24, 2006 - 7:32 PM
- - lagos   QUOTE(95celgt @ Apr 24, 2006 - 8:32 ...   Apr 24, 2006 - 9:14 PM
- - 95celgt   DAMMIT!!! It runs soooo much better at...   Apr 24, 2006 - 10:08 PM
- - lagos   you probably have a boost leak or something runni...   Apr 24, 2006 - 11:33 PM
|- - 95celgt   QUOTE(lagos @ Apr 24, 2006 - 11:33 P...   Apr 25, 2006 - 12:11 AM
- - LewFX   what did you do to the beast???   Apr 24, 2006 - 11:36 PM
- - 95celgt   Cool, I noticed the Breather filter attatched to t...   Apr 25, 2006 - 10:20 PM
- - lagos   i still dont understand why people use breather fi...   Apr 25, 2006 - 10:25 PM
|- - Rjb23   QUOTE(lagos @ Apr 26, 2006 - 3:25 AM...   Apr 26, 2006 - 12:53 PM
- - 95celgt   it came like that lagos:P but even then, it shoul...   Apr 25, 2006 - 10:31 PM
- - lagos   QUOTE(95celgt @ Apr 25, 2006 - 11:31...   Apr 26, 2006 - 3:00 AM
- - playr158   QUOTE(Rjb23 @ Apr 25, 2006 - 1:52 PM...   Apr 26, 2006 - 2:27 PM
- - lagos   QUOTE(Rjb23 @ Apr 26, 2006 - 1:53 PM...   Apr 26, 2006 - 2:35 PM
- - Rjb23   I don't have crappy idle or vac, I run 20 vac ...   Apr 26, 2006 - 3:17 PM
- - playr158   better yet.....get a catch can   Apr 26, 2006 - 3:29 PM
|- - Rjb23   QUOTE(playr158 @ Apr 26, 2006 - 8:29...   Apr 26, 2006 - 4:11 PM
- - Doge   I would listen to Lagos. Tee off your intake line...   Apr 26, 2006 - 6:20 PM
|- - Rjb23   QUOTE(Doge @ Apr 26, 2006 - 11:20 PM...   Apr 27, 2006 - 9:44 AM
- - 95celgt   The car has become undrivable from all the smoke i...   Apr 26, 2006 - 7:14 PM
|- - WannabeGT4   QUOTE(95celgt @ Apr 26, 2006 - 7:14 ...   Apr 26, 2006 - 9:31 PM
|- - phattyduck   QUOTE(WannabeGT4 @ Apr 26, 2006 - 7...   Apr 27, 2006 - 5:16 PM
- - playr158   QUOTE(WannabeGT4 @ Apr 26, 2006 - 10...   Apr 26, 2006 - 9:32 PM
- - WannabeGT4   Isn't a catch can a whole lot easier in our ca...   Apr 26, 2006 - 9:39 PM
- - lagos   or you could just hook it up the way toyota did it...   Apr 26, 2006 - 9:40 PM
- - 95celgt   LOL @ Lagos I finished running a hose to the Inta...   Apr 26, 2006 - 9:50 PM
- - Doge   The crankcase is not a vacuum... but the intake is...   Apr 27, 2006 - 11:30 AM
|- - Rjb23   QUOTE(Doge @ Apr 27, 2006 - 4:30 PM)...   Apr 27, 2006 - 3:13 PM
- - lagos   QUOTE(Doge @ Apr 27, 2006 - 12:30 PM...   Apr 27, 2006 - 11:40 AM
- - Doge   What's your point? The PCV needs the vacuum o...   Apr 27, 2006 - 3:47 PM
- - lagos   QUOTE(Rjb23 @ Apr 27, 2006 - 4:13 PM...   Apr 27, 2006 - 4:14 PM
- - 95celgt   guys, some help on a problem? Car runs crappy whe...   May 2, 2006 - 10:46 PM
- - lagos   can you tell us what "crappy" means?   May 2, 2006 - 11:02 PM
- - 95celgt   the extreme case of misfire when I give it throttl...   May 2, 2006 - 11:15 PM
- - lagos   did you see what happend to my car on the dyno whe...   May 2, 2006 - 11:47 PM
- - 95celgt   i put in the ngk's, and it ran crappier than t...   May 3, 2006 - 12:27 AM
- - Consynx   i run the 6097's by ngk, iunno what heat range...   May 3, 2006 - 12:58 AM
- - 95celgt   mine are brk6e? car misfires INCREDIBLY in vaccum...   May 6, 2006 - 5:00 PM
- - 95celgt   any ideas?   May 10, 2006 - 11:42 AM
- - lagos   have you checked for boost leaks?   May 10, 2006 - 11:44 AM
- - 95celgt   car runs good for days, some times it runs bad, i ...   Jun 30, 2006 - 1:49 AM
- - 95celgt   so i got bored today and decided to poke at the wi...   Nov 16, 2007 - 12:21 AM
Lo-Fi Version Time is now: August 27th, 2026 - 8:10 PM
