Mar 15, 2006 - 4:26 PM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '06 From Mary Land Currently Offline Reputation: 0 (0%) |
what are the little things that i can get for my celica performance-wise that make small improvements. thanks. i tried searching but is it just me or is the search feature...not very good.
Mar 15, 2006 - 4:30 PM
read my signature
however with the advanced timing you'll want to run 89 octane fuel as a precaution to prevent detionation. This post has been edited by Bitter: Mar 15, 2006 - 4:31 PM -------------------- |
Mar 16, 2006 - 10:27 AM
any other input?
Mar 16, 2006 - 10:31 AM
typical same things..that are found in the search
k&n drop in air filter header with full exhaust safc2 and thats pretty much as far as it really goes via cheapo performance if you wanna call it that... real power gains are going to come in the form of swaps or custom turbo kits which exceed 2000$....if ya wanna learn about that read the stickies in the FI section |
Mar 16, 2006 - 10:36 AM
QUOTE(playr158 @ Mar 16, 2006 - 10:31 AM) [snapback]408512[/snapback] typical same things..that are found in the search k&n drop in air filter header with full exhaust safc2 and thats pretty much as far as it really goes via cheapo performance if you wanna call it that... real power gains are going to come in the form of swaps or custom turbo kits which exceed 2000$....if ya wanna learn about that read the stickies in the FI section kinda expensive stuff. no new plugs or wires or little stuff like that would help @ all? anything for handling? struts? This post has been edited by Toyoca: Mar 16, 2006 - 10:40 AM |
Mar 16, 2006 - 11:04 AM
Enthusiast ![]() Joined Sep 27, '04 From Texas Currently Offline Reputation: 1 (100%) |
I put a low temp thermostat, bosch +4 plugs, thicker plug wires, flowmaster muffler, and hi-flow cone filter. The car feels like it has more torque at the low end and sounds freakin' awesome.
Mar 16, 2006 - 11:14 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
QUOTE anything for handling? struts? You could get a set of KYB GR-2 gas shocks (Or Koni Yellows, or Bilstiens) and have them accompany a set of TEIN S-Tech springs, or pretty much any spring/coilover you may find in the parts database. Suspsension Tech sway bars are nice, many members have them. defgeph is still selling (I think) rear strut bars and other goodies. In the performance dept. there isn't much you can do to make it faster w/o spending a lot of money. You can make an CAI and get an exhaust built (no one makes them) and get an SAFC tuned and you can get a bit from that. Suspension and handling I think is where our Celicas shine though. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Mar 16, 2006 - 11:21 AM
oh man if you like a 50$ filter is expensive your in the WRONG sport dude...
suspension wise sway bars, springs, strut bars ect.. ect.. bosch +4 plugs are just a waste of cash IMO they didn't run all that great, a set of NGKs are fine but don't expect any crazy gains from general maintanance...maybe a lil perkier if you havn't been keeping up with it... |
Mar 16, 2006 - 11:23 AM
QUOTE(playr158 @ Mar 16, 2006 - 11:21 AM) [snapback]408532[/snapback] oh man if you like a 50$ filter is expensive your in the WRONG sport dude... suspension wise sway bars, springs, strut bars ect.. ect.. bosch +4 plugs are just a waste of cash IMO they didn't run all that great, a set of NGKs are fine but don't expect any crazy gains from general maintanance...maybe a lil perkier if you havn't been keeping up with it... i meant these smartie "header with full exhaust, safc2" although guessing i meant the k&n was expensive is plausible for starters i probably have crappy sparkplugs so i guess ill start with those? so NGK? what kind. thinking ngk iridium ix? ty This post has been edited by Toyoca: Mar 16, 2006 - 11:30 AM |
Mar 16, 2006 - 11:31 AM
i got my K&N on ebay for about $25 shipped, i keep forgetting but i need to make that oiled foam prefilter for it. i have the foam somewhere but it just keeps slipping my mind.
Mar 16, 2006 - 11:36 AM
People keep saying bosch +4 are picky, but they run great in my car. Either way, if you have bad plugs now, you need to get new ones anyway. I would say any kind of plug with one element would be good to be on the safe side (just in case the +4's don't like your car).
Mar 16, 2006 - 12:10 PM
QUOTE(desertwolf300 @ Mar 16, 2006 - 11:36 AM) [snapback]408546[/snapback] People keep saying bosch +4 are picky, but they run great in my car. Either way, if you have bad plugs now, you need to get new ones anyway. I would say any kind of plug with one element would be good to be on the safe side (just in case the +4's don't like your car). bosch plugs are NOTORIOUS for causing misfire. the resistor material in them is of a very low quality and has a tendency to burn out causing excessivly high resistance through the plug, a weak spark, and misfires. also some of their plugs with the same numbers as oem or other plugs actually have a deeper reach into the cylinder which can cause problems if you've had your head machined flat or high cp pistons. -------------------- |
| Lo-Fi Version | Time is now: June 16th, 2026 - 5:59 PM |
