> abs hub vs. non abs, is there a dirffence
post Mar 16, 2006 - 1:52 PM
urbandork
Joined Jul 16, '04
From Los Angeles
i have a bad wheel bearing. Instead changing it i have access to hub with one already pressed in to it. The only thing is that its off a non abs version. both cars are gt's.
can a non abs hub go into a abs gt and still have the abs. i know the acxles is a diff story but not sure about the hubs, any one know?
post Mar 16, 2006 - 2:40 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
your abs light will stay on, the abs version has a piece on the end of the hub, non-abs does not...once your abs light is on your abs will not work. your brakes will lock up if you brake hard. i learned that already!
Lo-Fi Version Time is now: March 24th, 2026 - 5:14 PM
