> OEM Fog Light Switch, wiring...
post Mar 16, 2006 - 11:07 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Well I'm installing my OEM Fog Light "push" Switch I got on ebay- Switch located beside diver side vent. Its of of a ST202. I figured its alot cleaner look than after market switches. Anyways, I ran into some confusion on how to wire it. There are four wires. But the wiring (not stock) leading to my fogs now only consist of 2 wires- well at least from a quick glance under the dash. However, the wiring was from after market fogs (later I just hooked up OEM fogs using the same wirring) came with a light up switch (which I did not use). So I think the wiring has capability of lighting up a switch (I think).
Need some direction...
Does anyone know what each wire does? Can I neglect a couple of wires?
here's a pic of the OEM wiring from the button.
post Mar 16, 2006 - 11:11 PM
Jaws4God
Joined Mar 27, '04
in my experience... green is usually the power... white and black is ground..
post Mar 16, 2006 - 11:14 PM
Hanyo
Joined Aug 16, '03
From Bay area
there are 4 wires
wire a: ground
wire b: parking light ( so the switch lights up at night)
wire c: postive for relay
wire d: neg. for relay
only way to tell is to use a volt meter and measure the values of the wires.
post Mar 16, 2006 - 11:39 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(Hanyo @ Mar 16, 2006 - 11:14 PM) [snapback]408904[/snapback]
there are 4 wires
wire a: ground
Cool. THx Hanyo.
I think Jaws is right:
black/white are ground, green is power.
I think I remember orange being elumination.... so is the red/black wire for neg relay? Not sure what neg relay means. Is it the same as ground.... (I feel dumb)
heres a pic of the button on RHD
http://www.6gc.net/forums/index.php?showto...26&#entry380526
post Mar 16, 2006 - 11:54 PM
Shea_K47
Joined Oct 1, '05
im thinkin this is how it works. the led in the switch should have its own power and ground. on a stereo wiring harness ORANGE=ILLUMINATION so i geuss that would make GREEN=GROUND so u can wire those into your parking lights so the light comes on when you turn your headlights/park lights on. RED=NEGATIVE and BLACK/WHITE=POSITIVE on the fog relay. boom your set.
This post has been edited by Shea_K47: Mar 17, 2006 - 12:26 AM
post Mar 17, 2006 - 12:02 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(Shea_K47 @ Mar 16, 2006 - 11:54 PM) [snapback]408926[/snapback]
so you're using aftermarket wiring? are the fogs hooked up to just the switch/power/ground or did you use the stock relay?
Yeah its not a stock harness/wiring... I assume all the aftermarket wiring has is power/ground/and maybe elumination... just because the switch it came with had a light up switch.... but thats me assuming. I will be for sure tommorrow when I take a good look.
post Mar 17, 2006 - 12:14 AM
UT, do you know how to wire in fogs (aftermarket) ?
post Mar 17, 2006 - 12:24 AM
Shea_K47
Joined Oct 1, '05
i used to have after market fogs and the wires were positive(white)/negative(red)/ground(black). the LED needs its own ground but shares power with the fogs. then again i had them ghetto rigged. but that doesnt help ya here. refer back to my 1st post. rolleyes.gif
post Mar 17, 2006 - 5:44 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(Batman722 @ Mar 17, 2006 - 12:14 AM) [snapback]408941[/snapback]
Yeah I did it when I had aftermarket ones... but is was much easier because everything(switch/harness) was suposed to work together. Actually my bro helps me alot with wiring... he is pretty good at that.
post Apr 15, 2006 - 3:11 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Hey its me again. Finally getting around to installing the switch... but I thought I had everything figures out but the wire I thought was whate and black is actually white and green! What is this? does anyone know? Is it still ground?
thx,
Vic
Orange/Red: Button Illumination
Green: Positive
Red/Back: Negative relay?
White/Green: ? (ground ?)
Do I have this (somewhat) right?
This post has been edited by UTSlickVic: Apr 15, 2006 - 3:14 PM
post Apr 16, 2006 - 6:02 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
bump... for HELP
I must be color blind... OK, this is what wires I have coming out of the OEM switch:
GreenRed/Orange
White/Green
Red/Green
The wire colors I have on my aftermarket fog wire harness are:
Red
White
Black
I know what these (aftermarket harness) wires do, but what the hell do the OEM colors signify? Help... ?
My first attempt thus far has been connecting the following
OEM ------ Afternmarket Harness
green ---> Black
red/orange -----> did not connect (assumed it was illumination)
white/green -----> White
red/green ------> Red
This was just a test to see if it would work...this did not work.
I kinda followed what Hanyo listed. Can anyone give me some recommendations? I may have to just go junkyard hunting to look for an OEM harness.
Lo-Fi Version Time is now: August 21st, 2026 - 2:14 PM
