> Monster custom WAI pre-rad
post Mar 17, 2006 - 2:49 AM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
After a few days in the planning, the ball was set rolling by employing the services of a local radiator manufacturer. A core was ordered from Oz and less than 2 weeks later it was ready..
The OE pre-rad which has seen better days.
A few bolts to undo and the old one was removed.
As can be seen below, quite a difference in size between the new twin and the old single core rads.
New brackets were welded to the new unit which utilized the original mounting points.
The design allowed the PAS and gearbox coolers to be fitted as per factory.
The sharp eyed will have noticed the 2 brackets on the top of the rad.
These are to facilitate the mounting of an engine oil cooler.
Waiting for the crash bar and bumper to be re-fitted.
Went for a quick spin to ensure all was working well. Will recorded some measurements over the weekend after I've added some water wetter to the water and all the air has been bled from the system.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Mar 17, 2006 - 10:30 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Thats awesome. I might one day look into a new heat exchanger
I will return one day.
post Mar 17, 2006 - 10:43 AM
nice job! i bet it will do a much better job cooling the boost. but arent you worried that you are now blocking the engine radiator? the oem one is designed to be not as tall so that the top vent from the bumper can draw air in for the radiator, while the bottom one cools the heat exchanger. im sure it will be fine, but just something to keep in mind.
This post has been edited by lagos: Mar 17, 2006 - 10:46 AM
post Mar 17, 2006 - 10:56 AM
celicarus
Joined Jul 5, '05
From Arlington, TX
wow - radiator looks like a big FMIC --
will you even be able to fit a FMIC if you were to add one - looks like no space left - just wondering?
post Mar 17, 2006 - 11:10 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(celicarus @ Mar 17, 2006 - 10:56 AM) [snapback]409076[/snapback]
Thats a heat exchanger for the top mount w/a intercooler. As long as he has the W/A he'll never need a FMIC. The engine radiator is behind the new H.E.
post Mar 17, 2006 - 11:21 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
post Mar 17, 2006 - 11:33 AM
daymn, that H/E is huge....heheheh good stuff man!
gary, your project is amazing stuff man!
post Mar 17, 2006 - 3:33 PM
GT4WRC
Joined Mar 17, '05
QUOTE(lagos @ Mar 17, 2006 - 10:43 AM) [snapback]409069[/snapback]
Nope, not worried at all. I've fitted a huge Koyo ally ard which is extremely efficient. And this was confirmed when I went for a test run last night. Temp gauge didn't budge whatsoever on WOT runs.
Gary
GT-Four spec list
post Mar 22, 2006 - 4:11 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
QUOTE(GT4WRC @ Mar 16, 2006 - 11:49 PM) [snapback]409002[/snapback]
[color=#FF6600]\
looks like an angry celi, kind of. lol.
Lo-Fi Version Time is now: May 25th, 2026 - 5:04 PM
