Mar 20, 2006 - 7:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
ok guys, so i have an entire new set of doors with power options , door panels and wiring included, im going to swap this into my celica but im stuck.
how do you get into the door, like to disconnected/reconnect the power window regulator, or take off the manual one? theres no space, how would you replace the window? it seems as if there has got to be away to take off the inner most piece of metal so that you have access to the doors innards, is this possible? how would a shop do it. thanks -brian |
brianforster manual to power window conversion Mar 20, 2006 - 7:38 PM
brianforster does the regulator come out when you remove the gl... Mar 20, 2006 - 8:39 PM
Coomer The glass is held on by bolts only and will slide ... Mar 20, 2006 - 11:47 PM
brianforster the bgb guide on celicatech says to remove the gla... Mar 21, 2006 - 2:51 AM
Coomer I might go home tonight. If I do, I'll pull th... Mar 21, 2006 - 11:25 AM
devilsden97 i had my passenger side off, ill take it back off,... Mar 21, 2006 - 11:29 AM
brianforster thanks you two, ill be checking this thread religi... Mar 21, 2006 - 12:26 PM
Stu37363 im actually replacing my power window regulator to... Mar 21, 2006 - 12:45 PM
Coomer QUOTE(Stu37363 @ Mar 21, 2006 - 9:45... Mar 21, 2006 - 12:53 PM
Stu37363 if it will help you get started i know the window ... Mar 21, 2006 - 12:48 PM
brianforster i have already removed everything stu posted and s... Mar 21, 2006 - 2:32 PM
brianforster i think ive hit a major dent in the plan, the wire... Mar 21, 2006 - 3:00 PM
playr158 GIVE UP!
rock the black doors its cool to do i... Mar 21, 2006 - 3:01 PM
devilsden97 lol, i just got my interior panel off, and just ca... Mar 21, 2006 - 3:10 PM
playr158 he folded and is keepin the black doors Mar 21, 2006 - 3:12 PM
devilsden97 QUOTE(playr158 @ Mar 21, 2006 - 3:12... Mar 21, 2006 - 3:13 PM
Stu37363 i posted up the how to if your still interested. Mar 21, 2006 - 8:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 6:27 AM |
