> Power Window Regulator - How To Change
post Mar 21, 2006 - 8:15 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
This is assuming you have taken off your door skin...
Tools: screwdrivers, socket wrench, 10mm and 12mm deep socket
The bolts holding on the regulator and motor are circled
First you want to line up these holes by moving your window up and down
take these bolts (10mm) off and your window will slide out the top, you have to tilt the side connected to the car down to get the window stopper out.
Unbolt the top bolts (10mm) and slide these out
Unbolt the bottom bolts (10mm) slide this off, then remove the nut (12mm) underneath it.
Disconnect the motors wires, you have to unclip it from the car shown with the arrow, and disconnect if from the other clip. After that remove the three bolts holding the motor in.
Now the entire assembly will tilt and slide out the main hole in the door panel.
Replacement part
Remove these two bolts and the metal bracket they hold on.
With the cover removed you can use a flat screwdriver to pry the old pully off the motor
Once you have the motor and regulator back in, connect your window switch up and move the regulator up or down till these holes line up. Reinstall the window. Dont Tighten these bolts up all the way yet, leave enough for the window to move around.
Roll the window up and tighten them all the way using these service holes and the window should be lined up correctly. Just dont break your window tightening the bolts too much.
Install the door skin and your done
This post has been edited by Stu37363: Mar 22, 2006 - 10:56 AM
post Mar 22, 2006 - 12:07 AM
post Mar 22, 2006 - 4:51 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(Batman722 @ Mar 22, 2006 - 5:07 AM) [snapback]411202[/snapback]
agreed!
post Mar 22, 2006 - 5:34 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
How often do these regulator stop working?
and how much are they to replace?
I vote sticky as well!
6GC 4 Life Baby!!!
post Mar 22, 2006 - 10:51 AM
Stu37363
Joined Jun 30, '05
QUOTE (CelicaZR @ Mar 22, 2006 - 5:34 AM) *
not sure how often they stop working, my car has about 45k miles on it, but i smoke so that window goes up and down all the time.
the part cost me about $100 at a local dealership.
This post has been edited by Stu37363: Jun 11, 2008 - 10:26 AM
post Feb 13, 2007 - 7:52 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I find this very useful. Shouldn't it be stickied?
IPB Image <--- I miss :'' (
post Jul 25, 2007 - 6:10 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
my cable is broke so that means i have to replace to whole arm with cables 100$ bucks i dont have....but still good how to
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Jun 11, 2008 - 10:17 AM
STICKIE
post Jun 11, 2008 - 11:10 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
oh hot diggity dog, this covers about 3/4 of the info I need! yay! I'm SO bookmarking this!
post Jun 13, 2008 - 4:00 PM
xs94st
Joined Aug 11, '07
From Corona, CA
look thru the junkyards if ya can..i had a regulator for sale as i did this exact procedure, but i sold it to another member.
i bought the window, regulator, and switch for $65 at a pick-a-part. if ya have anything similar close by, i'd recommend it as it is summer and a quick fix will probably last ya a while until you can afford the new part. (the regulator alone was only $25)
This post has been edited by xs94st: Jun 13, 2008 - 4:01 PM
Pandelica 2.0 in progress.
post Oct 8, 2014 - 12:53 AM
benzo
Joined Jul 23, '09
From Fresno, Ca
how can you unscrew the last 3 bolts if your window cable is broke and cannot move the window up?
post Oct 27, 2014 - 7:15 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
http://www.1aauto.com/1994-99-toyota-celic...2063&y=1995
1995 Toyota Celica Power Window Regulator (Without Motor) Driver Side
I cant find this locally.. would this be okay?
damn.. yea i cant find it at any of the local shops. pick a part places around here are all picked. Gonna have to order it online.
Anyone have a cheaper source?
This is for a 1995 toyota celia (Duh haha) ST driver side power window regulator. That 1a auto is 109.95 plus shipping. Ill wait a day before ordering..hopefully one of you guys/gals can come thru with a better source. thanks in advance!
This post has been edited by benzo: Oct 27, 2014 - 7:29 PM
Lo-Fi Version Time is now: September 21st, 2026 - 10:56 PM
