Mar 23, 2006 - 11:12 PM
player is on this!
This post has been edited by LewFX: Mar 23, 2006 - 11:12 PM -------------------- ![]() |
Mar 23, 2006 - 11:15 PM
QUOTE(LewFX @ Mar 23, 2006 - 11:12 PM) [snapback]412245[/snapback] player is on this! ? you're so confusing. you confused me on my other thread now this? ai yi yi |
QUOTE QUOTE(LewFX @ Mar 23, 2006 - 11:12 PM) player is on this! he means me! your going to have to use coilovers.... so expect a slightly bouncy ride quality due to high spring rates and you'll have to get new struts KYB, bilstein or koni rubbing no shouldn't have any...i have 18x7.5" never had a problem w/more then a 2" drop just know it can wear your bearings out much faster then normal (i've replaced both fronts) ground clearance is goin to be around 5" or more i had an invader kit and supra bomex kit so my fronts were really low This post has been edited by playr158: Mar 23, 2006 - 11:17 PM |
Mar 23, 2006 - 11:18 PM
why do you say coil? 2" drop is low enough isn't it? or u talking about 3" drop? with 17" rims am i going to be up high? hm...lmk before i make my decision... |
Mar 24, 2006 - 1:07 AM
Enthusiast ![]() ![]() ![]() Joined Jan 29, '06 From Kitchener, ON, CA Currently Offline Reputation: 0 (0%) |
what he's saying is that to get a 2" drop, you'll have to go with coilovers rather than springs (Eibach's for example)
Mar 24, 2006 - 3:10 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
There aren't many springs out there that can achieve a 2" drop, so in order to get that you need to use coilovers. Don't buy Ebay brand coils. Go with Ground Control or Tein SS if you have the money. Like Playr said, get new shocks/struts either KYB's, Koni, or Bilstien.
What size tire do you plan on running? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Mar 24, 2006 - 8:48 AM
i have 17x7.5 rims so maybe 215-17-45? what's a good tire size? i've already found some springs that'll drop 2" front and 1.8" back...lmk guys...
Mar 24, 2006 - 9:10 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
I got a 3" drop on the front 2.5" in the back on 18x8's got to watch big bumps, other wise its all good...
This post has been edited by Punch: Mar 24, 2006 - 9:13 AM |
Mar 24, 2006 - 9:47 AM
it looks the same.....its only an inch difference in rim size....
you'll probably have about 6-9 inches worth of ground clearance in the front... "why do you say coil? 2" drop is low enough isn't it?" Coilover's are how you achieve a 2" drop "with 17" rims am i going to be up high? " now this doesn't even make sense.....how do you go up if your lowering? lowering means go down...makes you sit lower not higher but relationally a lower'd car on 14" wheels next to a car lower'd the same amount on 17" wheels might see a slight difference in ground clearance |
Mar 24, 2006 - 10:03 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
I started with stock 15's with around a 2inch drop (atleast as advertised) and it was very low... now since i got my 17's, the car is still low, but sits a little higher and makes speedbumps a little easier... the rim size difference will be noticeable in the height and how the car drives around town with bumps and what not
Mar 25, 2006 - 12:14 PM
I had 4'inches worth of ground clearance in the front... when my lip was on, until I let my best friend drive my car & he drove in a ditch & cracked the lip... (dont let Ford Probe guys drive your car)
| Lo-Fi Version | Time is now: June 23rd, 2026 - 11:17 AM |
