> bleeding the clutch, can anyone post a guide?
post Mar 24, 2006 - 12:15 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
any tips/suggestions? i have to do this today, seems easy, but my friend says to make a post just incase there are toyota specific things we dont know about.
Replies (1 - 7)
post Mar 24, 2006 - 12:36 PM
Chanh55
Joined Jun 29, '03
Pretty standard... nothing special.
post Mar 24, 2006 - 5:02 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Pump all the air out of the line.
I will return one day.
post Mar 24, 2006 - 5:25 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
take a vaccum line from the intake manifold and t into it. the hose you just ran, run into the lid of a peanut butter jar.
now have a hose coming out of the jar touching the bottom of the jar. and plug that one into the bleeding nipple.
then run the car and the vaccum will pull all the air out. once all the air is out tighten the nipple and your done.
This post has been edited by x_itchy_b_x: Mar 24, 2006 - 5:26 PM
post Mar 24, 2006 - 6:00 PM
QUOTE(x_itchy_b_x @ Mar 24, 2006 - 5:25 PM) [snapback]412733[/snapback]
umm who told u to do that? seems like a very odd way to bleed.
the correct way is to have somone pump the clutch pedal a few times and hold it down. then the other person puts clear tubing over the nipple and the end of the line goes into a small cup that you full with brake fluid. then turn the nipple to open thw flow, and watch for air bubbles. do this as many times as u need to, untill u see now more bulbbles. also, keep a close eye on the fill hole and keep adding fresh brake fuild into it so that it dosnt run dry and add more air into the system.
post Mar 24, 2006 - 7:11 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
its basicly a home made mity vac. a bleeding tool used so u dont need to do a bunch of pedal pushing smile.gif and now you only need one person.
http://www.toolsource.com/ost/product.asp?...2G5FU0KJBV64VB0
post Mar 24, 2006 - 7:24 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
those things work OK for a while but the rubber in them isnt made to handle brake fluid and it'll be dead in a year :lol:
post Mar 24, 2006 - 8:18 PM
QUOTE(x_itchy_b_x @ Mar 24, 2006 - 7:11 PM) [snapback]412777[/snapback]
i would be scared to suck up brake fluid into the engine through that vac line.
they sell bleeding lines at pepboys for 3 bucks. its just a hose with a 1 way check valve in it. all you do is open the nipple and pump the pedal , if you want to do a one man job.
Lo-Fi Version Time is now: August 28th, 2026 - 12:14 AM
