Mar 25, 2006 - 2:05 AM
Enthusiast ![]() Joined May 23, '05 From Sauga Currently Offline Reputation: 0 (0%) |
Ok, so I've run into another problem, I was trying to bleed my clutch, but I can't even press down on the clutch pedel, so I open up the bleeder valve by the clutch fork or the slave cylinder. When I press on the clutch with the valve open, the clutch goes all the way to the floor, and it pumps out the fluid with ease. As soon as I close the valve the clutch pedel locks up and I'm not able to step on it at all again.
3sgte@daspeedof Clutch Problem Mar 25, 2006 - 2:05 AM
3sgte@daspeedof Bump anyone have any ideas? Mar 25, 2006 - 10:23 AM
lagos you have to pump the clutch pedal with your hand. Mar 25, 2006 - 11:24 AM
3sgte@daspeedof Just wanted to say thanks for the help, I pulled t... Mar 26, 2006 - 10:20 AM
Bitter oil contamination could have caused the lip seals ... Mar 26, 2006 - 11:36 AM
3sgte@daspeedof Ok, so how do I blead or better yet flush the whol... Mar 26, 2006 - 9:40 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 8:46 AM |
