> Stuck Idling at 2,000
post Mar 28, 2006 - 12:12 PM
BlackCelicaGT94
Joined Mar 4, '03
From Kirkland, Washington
I was driving the other day and found myself stuck idling at 2,000 rpm everytime i came to a stop. Any explanations? it did it for about half an hour and then hasnt done it again since.
Thanks in advance for any help!
post Mar 28, 2006 - 1:15 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Sometimes the vibration from the motor moves the bolts that hold the throttle cable in place on my car. This will cause the idle to sick higher. I stick my foot under the pedal and pull it up and it goes back down to normal. If you can do that, I think that'll be your problem. Otherwise, I could be something with the air intake. Have you checked to see if it's clean? Sometimes that can make your idle go a little funny.
Live Free, Be Happy
post Mar 29, 2006 - 8:11 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Could be a vacuum leak, get some carb cleaner and spray it around your intake, if your idle suddenly goes up then that's your leak.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 29, 2006 - 8:58 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE(Dr_Tweak @ Mar 29, 2006 - 8:11 AM) [snapback]415018[/snapback]
-Doc
What he said. Another thought would be a sticky IAC.
post Mar 29, 2006 - 10:25 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
QUOTE(Fastbird @ Mar 29, 2006 - 8:58 AM) [snapback]415029[/snapback]
-Doc
well if its sticky thats why tweak recommended carb cleaner to clean it, that IAC is about 180-200+, not a cheap part for a little piece, so try carb cleaner for a buck.
post Mar 29, 2006 - 10:56 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE(LewFX @ Mar 29, 2006 - 10:25 AM) [snapback]415056[/snapback]
-Doc
No, Dr. Tweak recommended spraying carb cleaner around the intake because as soon as it hits the vacuum leak it will get into the combustion process and make the idle jump. If no vacuum leaks are found, my recommendation would be to take the IAC off and clean it with a carb cleaner. Just spraying around the intake isn't going to affect the IAC at all unless you spray it directly into the IAC intake passage.
post Mar 29, 2006 - 11:14 AM
QUOTE(Fastbird @ Mar 29, 2006 - 10:56 AM) [snapback]415073[/snapback]
-Doc
agreed
post Mar 29, 2006 - 2:51 PM
scothaniel
Joined May 1, '03
From Michigan
Or use propane / map gas (soldering torch). Same situation as the carb cleaner.
Scott
West Michigan
post Mar 29, 2006 - 3:19 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE(scothaniel @ Mar 29, 2006 - 2:51 PM) [snapback]415188[/snapback]
post Mar 29, 2006 - 3:39 PM
scothaniel
Joined May 1, '03
From Michigan
No really! It works great. I use it all the time looking for exhaust leaking in IC piping. No mess and not harmful to rubber seals.
Scott
West Michigan
post Mar 29, 2006 - 3:52 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
scothaniel, I wasn't making fun of you. The thought of a large bottle of propane, an uncontrolled propane release, and engine combustion immediately jumped into my head when I saw that you mentioned it.
Lo-Fi Version Time is now: June 28th, 2026 - 12:21 AM
