Mar 29, 2006 - 1:38 PM
Enthusiast ![]() ![]() Joined Sep 24, '03 From Medina, OH Currently Offline Reputation: 11 (100%) |
I know on some of my friends cars you can yank the e- brake and lock up the back tires and all and the brake seems very strong but my e brake wont even hold the car on a small incline and never has worked too well.
I was just wondering the first things you guys would check out? i figured the wire was pinched somewhere and the wire was just stretched out but i still wanted your opinions BTW: its a 94 ST and ive adjusted it so it starts to pull at about 7 or 8 "clicks" but its still real weak and u know just somthing isnt right about it Thanks in advance -B This post has been edited by CelicaB: Mar 29, 2006 - 1:38 PM |
Mar 29, 2006 - 2:23 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Where did you adjust it at? the rear wheels? I would tighten it up back there. If you take your drum off the back there will be a little wheel-looking thing with many-a-teeth. click that over a few times. If I remember correctly, that is your e-brake tensioner.
Mar 29, 2006 - 2:26 PM
yeah i figured id try that after i didnt see anything too visible... i assume they did that when they redid the rear brakes
but is has always been really weak even before i got new drums and shoes -thats kinda why i figured it was the wire somewhere? This post has been edited by CelicaB: Mar 29, 2006 - 2:27 PM |
Mar 29, 2006 - 5:30 PM
Enthusiast ![]() ![]() Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) |
Im not sure, but theres a nut where the e-brake is, id take a pic of it if you need me to. But i think its like 10mm nut, just tighten that. That worked for me.
Mar 29, 2006 - 9:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
Check the spring near the tensioner, might be old, streched, or not connected.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Mar 30, 2006 - 1:54 PM
ok thanks everyone
i guess ill just have to go back through starting with your suggestions |
Mar 31, 2006 - 6:38 PM
QUOTE(sugarfree @ Mar 29, 2006 - 5:30 PM) [snapback]415268[/snapback] Im not sure, but theres a nut where the e-brake is, id take a pic of it if you need me to. But i think its like 10mm nut, just tighten that. That worked for me. do what he said ... depending on how warn you drum an or shoes are .. you might have to tighten the to 10mm nuts all the away down ... thats what i had to do ... now my ebrake holds my car on ever step hills... with only 2 clicks .. -------------------- |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 11:37 PM |
