Mar 30, 2006 - 9:42 AM
Enthusiast ![]() Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
I think it needs some cleaning and a few new things like gaskets, belts, spark plugs for sure. and the do you guys think about the exhaust manifold? That one is real rusty.
thats what the front clip looks like. Here is some of the stuff I think I might need. Can anyone tell me what this thing is? And here is the exhaust manifold and the crazy oil leaking from engine there is also orange stuff on the engine that seems to be coming from some where?
Mar 30, 2006 - 9:47 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
1.) looks like a noise filter.
2.) that orange stuff is called gasket sealent. 3.) You should smack the place you bought the clip from cause it looks terrible, leaking oil in the valve cover and obviously rusty. Im sure it has 100K miles already. This post has been edited by soulshadow: Mar 30, 2006 - 9:49 AM |
What does it do? Do I need it?
Mar 30, 2006 - 10:00 AM
There are 115135 on it is that miles or kilometers? I guess I have to fix the engine up it's gonna cost more then I thought it would have. I should have just bought the engine and wasted my money that way
Mar 30, 2006 - 10:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
How much did you pay for it?
~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Mar 30, 2006 - 10:52 AM
#1 is the resistor packs for the injectors and fuel pump, yes you need them
Mar 30, 2006 - 11:30 AM
just give that manifold a little love and care. wire brush it then send it out to be powder coated. or chromed lol
Mar 30, 2006 - 11:34 AM
Enthusiast ![]() Joined Mar 9, '06 From Crete - Greece Currently Offline Reputation: 0 (0%) |
I am afraid that you will have more troubles than the exterior problems of this engine.. It seem that it had very tough times when it was united with the rear cut..
Mar 30, 2006 - 11:36 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
QUOTE(ToysRfast @ Mar 30, 2006 - 3:00 PM) [snapback]415586[/snapback] There are 115135 on it is that miles or kilometers? I guess I have to fix the engine up it's gonna cost more then I thought it would have. I should have just bought the engine and wasted my money that way thats in km so its around 72k miles. bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Mar 30, 2006 - 11:45 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Its not bad...what manifolds arent rusty? Someone just used some orange RTV to try and seal the valve cover. Just replace the gasket and get a twosrus allen bolt kit to tighten it down.
Mar 30, 2006 - 11:46 AM
I payed 1400$ for the front clip.
Mar 30, 2006 - 11:57 AM
also i wanna say replace EVERYthing you can.
water-pump, distributer, plugs, fuel filter,belts, esp the head-gasket if needed. do a compression check just to make sure. that will show you a definite leak but a compression test wont help if the hole is very small and only leaks with boost, much more psi would have to be pumped in the cylinders to check for such a small hole. also check for any signs of oil and coolant mixing. like the underside of the oil cap. look for a milky substance. almost like an oil and coolant milk shake. when you have the exhaust manifold off check to see if the ports coming out look normal (covered in black carbon) and not squeaky clean, if one port is extremely clean compared to others than that cylinder has coolant entering it. also check the old coolant, if there is any still in the radiator for oil. im just saying that from experience. it sucks to have to redo things when the motor is already in. take what the people who sold you the engine say with a grain of salt. This post has been edited by x_itchy_b_x: Mar 30, 2006 - 12:07 PM -------------------- |
Mar 30, 2006 - 12:10 PM
QUOTE(x_itchy_b_x @ Mar 30, 2006 - 10:57 AM) [snapback]415640[/snapback] also i wanna say replace EVERYthing you can. water-pump, distributer, plugs, fuel filter,belts, esp the head-gasket if needed. do a compression check just to make sure. that will show you a definite leak but a compression test wont help if the hole is very small and only leaks with boost, much more psi would have to be pumped in the cylinders to check for such a small hole. also check for any signs of oil and coolant mixing. like the underside of the oil cap. look for a milky substance. almost like an oil and coolant milk shake. when you have the exhaust manifold off check to see if the ports coming out look normal (covered in black carbon) and not squeaky clean, if one port is extremely clean compared to others than that cylinder has coolant entering it. also check the old coolant, if there is any still in the radiator for oil. im just saying that from experience. it sucks to have to redo things when the motor is already in. take what the people who sold you the engine say with a grain of salt. I say replace the turbo too with something bigger. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 30, 2006 - 12:38 PM
I know what the head gasket is but what is a the esp?
Thank I will get what I can done with the engine. |
Mar 30, 2006 - 12:45 PM
oh esp is my abbreviation of especially. since the head gasket is a vital gasket.
Mar 30, 2006 - 1:52 PM
Oh ok THANKS
Mar 31, 2006 - 12:32 PM
Can someone tell me more about what type of clutch I need for the swap? I use the 5SFE tranny with the 3SGTE motor. I ask because I just called Spec preformance clutch and the guy put me on hold and never answered the phone again
Mar 31, 2006 - 12:50 PM
yea you should contact a different person from spec
READ the stickies "Lagos wrote: Clutch: if using the gt tranny with the 3sgte motor, you will need: 5sfe disk (or a custom made 3sgte disk, with the splines for the 5sfe tranny) 5sfe throwout bearing 5sfe alignment tool 3sgte pressure plate 3sgte flywheel (or just get your stock one resurfaced)" |
Mar 31, 2006 - 12:55 PM
The the 3sgte flywheel will work with the 5sfe tranny?
Mar 31, 2006 - 4:12 PM
yes..
| Lo-Fi Version | Time is now: May 25th, 2026 - 7:02 AM |
