Mar 30, 2006 - 12:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
So I did the rear disc swap 2 years ago. I noticed that I would get some clicking and humming noise from my rear D/S and now my rear p/s tires. i figured that it was my wheel bearings, but I took my car to toyota today and said I think my bearing are bad. well they called back and said it wasn't my bearings; those are fine. They aren't sure whats causing the noise. They suggest that its the rotors cause of the air, but Im not sure. I asked them to make sure everything was in working order incase I did something wrong. According to them everytthing is working correctly and nothing is loose....
So now Im at a loss of what could be the problem... does anyone have any ideas what I Can look for/ check? or if you have extra noise from these rotors let me know. Its kinda annoying and loud and I'd like it to go away. Thanks for the help |
Jeremy1210 Cross drilled/ slotted Rotros Mar 30, 2006 - 12:14 PM
Bitter i have slotted front rotors and i will hear a ... Mar 30, 2006 - 12:29 PM
Jeremy1210 The clicking is constant in the rears. Once I hit ... Mar 30, 2006 - 12:33 PM
playr158 check and make sure its not hitting the backing pl... Mar 30, 2006 - 12:35 PM
Jeremy1210 Cool, ill hve to check that this weekend, isf its ... Mar 30, 2006 - 1:52 PM
team_omega Did you change tires recently? If you did then it... Mar 30, 2006 - 10:35 PM
LewFX yeah the noise was from the rotors, because when i... Mar 30, 2006 - 11:19 PM
celicarus if you can get stock rotors then compare the diffe... Mar 30, 2006 - 11:50 PM
LewFX it is the rotors, i just said i changed the rears ... Mar 31, 2006 - 12:02 AM
Insanity-74 Sounds like mildly warped discs to me. Had the sam... Apr 1, 2006 - 2:46 AM
LewFX i thought you couldnt machine slotted or drilled r... Apr 1, 2006 - 10:05 AM
Jeremy1210 Yeah, I beleive that it is the rotors like what Le... Apr 2, 2006 - 4:24 PM
LewFX mine cant be warped since they are practically new... Apr 2, 2006 - 4:43 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 17th, 2026 - 7:05 AM |
