> Got My 'RC' Motor Today, very interesting
post Apr 4, 2006 - 8:09 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
I recieved my motor today. Here's some pics. The mine's ECU almost makes me believe that this might be a standard 185 motor with the W/A IC swapped over. This is supported by the fact that I asked for the AFM and he sent me a standard 185 one. Is there any other way to check to verify that this is an RC motor? Thanks. (Deph in particular biggrin.gif)
post Apr 4, 2006 - 8:28 PM
zachattack15
Joined Aug 16, '04
From Baton Rouge, LA
Didnt you already have a swap?
post Apr 4, 2006 - 8:33 PM
nice 2nd motor.
post Apr 4, 2006 - 9:56 PM
QUOTE(Doge @ Apr 4, 2006 - 9:09 PM) [snapback]417891[/snapback]
post up the part #, it should be listed on it. One of us will verify it.
post Apr 4, 2006 - 11:11 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
It has a timing belt cooler which is an RC part. Thats funny they gave you the 185 AFM. Maybe thats the reason for the upgraded ECU, to make up for the stock AFM.
I'd give that motor a complete rebuild.
Good luck
I will return one day.
post Apr 4, 2006 - 11:55 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
QUOTE(Doge @ Apr 4, 2006 - 8:09 PM) [snapback]417891[/snapback]
Here you go.... http://www.alltrac.net/phpBB2/viewtopic.php?t=12680
This might help a bit.. If you want the part numbers, here it is
The AFM part number 22250-74250
The RC ECU part number 89661-2B310
The ECU part number 89661-2B280(I have two of these don't know if its RC or not)
The harness part number 82121-2G770-C
The Igniter part number 89621-12050
This post has been edited by team_omega: Apr 4, 2006 - 11:59 PM
post Apr 5, 2006 - 1:12 AM
tufy
Joined Dec 3, '03
From Cyprus
i use to have mines ecu too. mines put a chip in ecu and eliminates speed limiter and converts car to 100 octane fuel. probaply you have a rc ecu with mines chip which means you are so lucky wink.gif
post Apr 5, 2006 - 7:21 AM
Doge
Joined Dec 2, '02
I wish I could check the ECU part number but Mine's seems to have taken the identification off of it. I know for sure the AFM is a regular 185... the part number is the same as my other 3s. Any other way to verify? Omega are those part numbers all for RC components or are the harness and ignitor part numbers the same as a regular 185?
post Apr 5, 2006 - 7:39 AM
tufy
Joined Dec 3, '03
From Cyprus
here is my old ecu and part numbers on it. mines does not take off numbers on it. only place guaranty plaque and safety stickers side
This post has been edited by tufy: Apr 5, 2006 - 7:48 AM
post Apr 5, 2006 - 10:08 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
w2a :jealous:
post Apr 5, 2006 - 10:22 AM
94wrc
Joined Mar 24, '06
From Slough,Berkshire,UK
Best thing I could suggest is go on to www.gt4oc.net and ask on there, we have lots of 185 RC/CS owners who should be able to tell you straight away or at least tell you what to look for. A few words of advice, get a metal head gasket put on ASAP as those are the weak point on the 185 lumps, luckily the 205 has one as standard.
HTH
Nathan
1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
post Apr 5, 2006 - 12:39 PM
Doge
Joined Dec 2, '02
Thanks for the head gasket advice 94wrc. I'll definately do that. The only problem is gt4oc.net has a charge for access to their forums. I would do it but I can't justify any expenses at this moment. Would it be possible for you to make a quick run-through on the forums over there and see if you come across anything?
I wonder why the sticker was taken off of the ECU... hmm... I'm gonna call the importers right now.
post Apr 5, 2006 - 4:56 PM
scothaniel
Joined May 1, '03
From Michigan
Open up the ECU and look at the pinout stamped on the board. The existance of an INT pin should tell you if the ECU is an RC.
Did you get the WA intercooler ECU with the swap?
This post has been edited by scothaniel: Apr 5, 2006 - 4:58 PM
Scott
West Michigan
post Apr 5, 2006 - 11:55 PM
team_omega
Joined Aug 14, '05
QUOTE(Doge @ Apr 5, 2006 - 7:21 AM) [snapback]418025[/snapback]
Those are the part numbers for the RC....Its fits on to my motor perfectly. The harness also has the WTA harness plug on it. Don't know about the ignitor. Does your AFM have 7 pins or 5 pins? If 5 pins then you have RC AFM.
post Apr 6, 2006 - 1:19 AM
Doge
Joined Dec 2, '02
Opened up the ECU only to find this... no pinout diagram. The harness did have the plug for the intercooler... however the ecu plug has been chopped. I called them and expressed my disapproval. I have a feeling there is going to be a major wiring issue... even though I already have a working harness from my previous 3s.
Good news is: They told me to send back the AFM and they will send the correct one. Lets just hope they still have it.
P.S. To those wondering about my first 3s: Long story short I let my friend borrow it for a day and it came back in pieces... I hope you all learn from my mistake... It's like they killed my child.
This post has been edited by Doge: Apr 6, 2006 - 1:19 AM
post Apr 6, 2006 - 10:02 AM
scothaniel
Joined May 1, '03
From Michigan
You can definately tell if the AFM is an RC - its like 50% bigger in size. Wiring wise, it has one extra ground. The sensitivity of the meter is different from the standard 185 - if you put the RC AFM on a standard ECU you'll run really rich.
Scott
West Michigan
post Apr 15, 2006 - 11:07 PM
Doge
Joined Dec 2, '02
I've been searching for any sort of ecu pinout diagram for the rc... to no avail. So since it's not looking good in that department... is there any way to find out which pin goes to where? Or am I pretty much f'd?
post Apr 15, 2006 - 11:14 PM
QUOTE(Doge @ Apr 16, 2006 - 12:07 AM) [snapback]422028[/snapback]
you should be able to just plug that ecu into your old harness. the pinouts on the "rc" ecu are the same as a normal st185
post Apr 15, 2006 - 11:20 PM
Doge
Joined Dec 2, '02
That means I'm really f'd then... because this "mine's" ecu has completely different pin placements... not even close
Edit: What about the AFM wiring? Doesn't the RC AFM have more/less wires going to it? What are those extra wires doing?
This post has been edited by Doge: Apr 15, 2006 - 11:40 PM
post Apr 16, 2006 - 7:51 AM
scothaniel
Joined May 1, '03
From Michigan
RC ECU wiring is similar to the 92-93 standard ST185 wiring. The 90-91 harness is a bit different. You'll also have extra wires for the IC setup as compared to the standard 185 harness
The Mines ECU should have the same pinout as the RC, since they've basically remapped the stock ECU.
The RC AFM has one more wire compared to the standard 185 ECU. This is just another ground (dedicated to the temp sensor instead of sharing the ground wire between them).
Scott
West Michigan
Lo-Fi Version Time is now: August 25th, 2026 - 2:52 AM
