Apr 8, 2006 - 2:38 AM
Enthusiast ![]() Joined Mar 19, '06 From augusta ga Currently Offline Reputation: 0 (0%) |
Hey i was just wondering my check engine light came on
and stays on the code it is giving is 7fast pause 1 flashes which after running a search for engine codes the chart i found a link to says 71 is the egr system ...... my question is that my celica a stock 94 st has a knocking sound when it revs between 3,500and 4,000 rpm sounds more like a acorn being shook inside a soda can other than that and since the light came on it bucks lightly when cruising it has no other problems engine wise that i can tell could the egr system be causing this? it has 225,000 miles if it is the original engine the wierd part is if it was a bearing wouldn't there be metal shavings in the oil from what ever bearing is causing the sound? also when i was under the hood revving it up it sounds like the noise is coming from up top thanks for any help. -------------------- 94 st
| Lo-Fi Version | Time is now: August 26th, 2026 - 12:11 PM |
