> windshield washer nozzles, water doesnt come out
post Apr 10, 2006 - 5:12 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
any1 knows how come the "mist" function doesn twork?...i bought the 6gc last year and it hasnt worked ever since...jus finally got the time to deal with this.....is it cuz of the washer pump?.....iono...help plz....
post Apr 10, 2006 - 6:49 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
clogged nozzles, clogged line.. check the pump.. mabey wiring.
DTE
I am a thief.
do not buy anything from me.
post Apr 11, 2006 - 10:31 PM
sinner96ST
Joined May 15, '03
From Aurora IL
Sometimes wax gets caught in the little nozzles, happened to me more than a few times, visually inspect them and see if you have it caked around the sprayer. I used a toothbrush to get rid of the wax inside, and it works great.
post Apr 11, 2006 - 10:55 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ive tired takin the nozzle out of the hose n tried the mist function but to no clonclusion...ill try to check the wiring & teh pump...
post Apr 11, 2006 - 11:19 PM
slo8012
Joined Apr 11, '06
From Michigan
I have something crazy to try... i thought for sure that my mist was broken, but then i tried the button on the end of the stalk, instead of turning the stalk. nothing was wrong with the system, except that the icons on the stalk didnt really indicate how it worked. I assumed it worked like all the other cars i had ever driven.
Try the button in addition to turning the stalk.
post Apr 17, 2006 - 7:56 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
I've got a '94 and I've had to replace my washer pump twice. To access it you'll have to remove the plastic wheel liner from your passenger side wheel. Then before you start tearing it apart you can have someone hold the button down while you listen to see if it actually makes any noise. It's a fairly simple replacement because you just pull the old one out of the reservoir. If you buy one from Advance it just pops right in, but it doesn't have a line for the rear washer so you just have to leave that one disconnected or figure a way to tie it in with a T so that it washes the rear and the front simultaneously. Good luck.
post Apr 17, 2006 - 8:50 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
Is there washer fluid in it?
may sound dumb, but when my sprayer didnt work there wasnt any fluid in it.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Apr 19, 2006 - 2:17 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(recneps @ Apr 17, 2006 - 8:50 AM) [snapback]422447[/snapback]
that's what i was gonna ask, 90% of the people i know who think their washer sprayers are broken just ran out of fluid
1999 Celica GT
post Apr 19, 2006 - 8:24 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
plenty of fluid......ive tried taken out the nozzle n tried the mist function still nothin..ill try to take an indepth look into the pump...i think its teh major cause....
post Apr 22, 2006 - 9:35 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ok i jus went to advance n bought the washer pump..its for a coupe/vert....thas all they have available for my 6gc...i wanna kno is it goin be different between n coupe/vert & hb?...im goin try to install it tomorrow..jsu wanna kno some info b4 i start on this...
post Apr 23, 2006 - 5:58 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
well hopefully it has a line for the front and back. if not you will probably have to make it only work for the front. you may need to splice too... really i think you should just return that and get one for a hatchback if it doesn't have a rear pumpline, since the 2 line one is 3 wires, and the single line pump is 2 wire.
Lo-Fi Version Time is now: August 21st, 2026 - 9:01 PM
