Apr 10, 2006 - 11:53 PM
Enthusiast ![]() Joined Nov 30, '05 From British Columbia, Canada Currently Offline Reputation: 1 (100%) |
alright guys, heres my situation, im not getting very good mileage in my opinion. city driving, im getting, (remember im canadian) about 385 km to about 55L, which i changed to (good chance i may be incorrect haha) 231 miles in 15.79 gallons which i work out to be about 14.63 MPG, now thats pretty damn low in my opinion assuming i am correct. what would i check or replace first to get better mileage? thanks guys.
Apr 10, 2006 - 11:58 PM
first, basic tune up - plugs, wires, cap, rotor, oil change, filters
if still bad, probably 02 sensor... -------------------- |
Apr 11, 2006 - 1:50 AM
Enthusiast ![]() ![]() Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) |
I was getting about 400-450km's on my gts till the fuel light goes on.. after a tuneup, timing belt/water pump, I'm hitting 500's b4 the light.
Definitely check your timing belt and think about a tuneup (plugs, wires, cap, rotor, fuel filter, pcv valve). |
Apr 17, 2006 - 9:33 AM
Enthusiast ![]() Joined Mar 17, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(cg97 @ Apr 11, 2006 - 12:53 AM) [snapback]420062[/snapback] alright guys, heres my situation, im not getting very good mileage in my opinion. city driving, im getting, (remember im canadian) about 385 km to about 55L, which i changed to (good chance i may be incorrect haha) 231 miles in 15.79 gallons which i work out to be about 14.63 MPG, now thats pretty damn low in my opinion assuming i am correct. what would i check or replace first to get better mileage? thanks guys. Hello, I was looking at your conversion and I think it's off a little. To convert liters to gallons: (multply liters by 0.2642 to get gallons) 55 liters = 14.53 gallons To convert kilometers to miles (multply kilometers by 0.62 to get miles) 385 kilometers is equal to 239.23 miles So you drove 239.23 miles and burned 14.53 gallons of fuel. For that trip you got 16.46 miles per gallon. I agree with Batman722 and Starcraftjunkie that a tune up (plugs, wires, cap, rotor, fuel filter, air filter, pcv valve) would be time and money well spent. If you're still getting low mpg after the tuneup check for Diagnostic Trouble Codes. Yellow94GT |
Apr 17, 2006 - 10:56 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
Is the CEL light on? In that case make sure to run codes as bad sensors can lead to not only the engine running odd but also bad gas mileage.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Apr 17, 2006 - 11:43 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Quick question, When an O2 sensor goes bad, what happens? It thinks the car is running lean so it tells the ECU to dump in more fuel? Is that where the bad milage comes from?
Apr 17, 2006 - 8:52 PM
QUOTE(hitcachi @ Apr 17, 2006 - 10:56 AM) [snapback]422494[/snapback] Is the CEL light on? In that case make sure to run codes as bad sensors can lead to not only the engine running odd but also bad gas mileage. CEL light? haha sorry what is that? there are no odd lights on, on the dash. so shoudl i do the trouble shooting thing? -------------------- ![]() |
Apr 18, 2006 - 9:06 PM
It stands for "Check Engine Light"
| Lo-Fi Version | Time is now: September 3rd, 2026 - 11:45 AM |
