> CV Axle breaking apart over and over and over...., GIVE ME A SOLUTION PLZ IM BEGGING!
post Apr 15, 2006 - 2:40 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
Just about 3 days ago, i hear my cv axle going bad. So i went to oreilly to get the refurb. I went straight home and take the hub and everything off to replace it, got it done in about 3hrs, test drive it for about 1min and it snaps out. (where the tripod and the boot are) Okay.. i thought it might be just a bad one, so i go back and reorder another one. SAME **** HAPPEN AGAIN! TODAY!!!!!!! i wont get another one till monday, cuz thats all dallas has. So what am i doing wrong? i just put everything back where it was. its simple. Could kyb + tanabe springs do anything? i dont think so. SO PLZ HELP ME GUYS! im begging. ill take pix if needed.
-Son
This post has been edited by My2Celi: Apr 15, 2006 - 2:40 AM
IPB Image <--- I miss :'' (
post Apr 15, 2006 - 3:23 AM
J-TYPE
Joined Mar 16, '05
From Toronto, Ontario
could be the axles that you are getting, they might not be the right ones...i had similar problem with mines and had to go through 6 new rebuilt axles and all from different shops. so far the one i have installed now is holding up pretty good. you should try picking up a used one from the junkyard or something.
post Apr 15, 2006 - 7:59 AM
yea, that definetly sounds like you could be getting a wrong part or somthing...which axle is it?
post Apr 15, 2006 - 11:28 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
Well i got it from O Reilly. looks exactly like my old one. Could i have torque the spindle nut too much? im stressed. I couldnt sleep cuz its parked in the ghetto of arlington right now. Since it was dark i hope i didnt park on a no park zone... other than that i dont think i could do anything wrong.
post Apr 15, 2006 - 11:54 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
the inner cv joint is coming apart repeatedly with new axles? which side? or is it the outer joint?
post Apr 16, 2006 - 3:07 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
QUOTE(Bitter @ Apr 15, 2006 - 11:54 AM) [snapback]421881[/snapback]
the inner, and its the driver side. i think it might be my bearings or the brakes that is holding the axle spindle. cuz i hear my brakes scratching on it. When i took my brake caliber out i didnt take out the pads either. so iono it could be that or i dont know what im really talking about. but do u have a solution or know why?
post Apr 16, 2006 - 10:11 AM
Bitter
Joined Mar 11, '06
is your suspension modified? the inner joint is the plunge joint that allows the axle to change lenght as the wheel moves up and down. when it pops out like that its normally a suspension issue, like the suspension moved up or down beyond the joints range of movement.
try another brand of axle assembly and if you still have an issue then just take it to a shop and explain whats been happening.
post Apr 16, 2006 - 10:34 AM
Same thing happened to me. My CV went, so I got a new one, and the whole CV came apart. Happened 2 times, after that I got the E153 so I didnt really resolve it.
post Apr 17, 2006 - 12:48 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
yay i found the solution. when the first cv axle went out on me, the grind before the snap ring snaped inside the tranny and when i put the second cv axle broke on me, the part before the snap ring broke inside the tranny too. I spend probably about 1hr trying to dig it out and i got it out. and so yay oreilly has one in stock and i got it working now... THANKS for the help guys.
post Apr 17, 2006 - 1:57 AM
Ralph96gt
Joined Apr 16, '03
From Los Angeles CA
the exact same thing happened to me a couple months ago. my cousin and i replace both of my axles cause i said might as well do both at the same time and the very nest day as soon as i got off the freeway i was at a stp and i heard a clunking noise and sure enough the bott was split open and the axle was hanging. but i went to the place where i bought them and they gave me all new ones and they have benn working fine ever since.
Click HERE for more pics of my Celica
post Apr 17, 2006 - 8:08 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
People, people, make sure that when you order it's for your ST not GT and GT not an ST axel. If you don't know what you are doing, than perhaps take it to a mechanic.
Yes, the snap ring is the most important part in a CV axel, make sure you put it in correctly by tapping in the axel and not just pushing it in with your hands and think that its in cause it's not!
Lo-Fi Version Time is now: September 3rd, 2026 - 8:58 AM
