> Climate Control Broken, Fan won't blow, controls won't light up.
post Apr 19, 2006 - 7:27 PM
BlackSTX
Joined May 17, '03
From Florence, KY
My climate control is broken. The buttons won't light up and the fan won't blow. It does absolutely nothing. Is this a fuse problem maybe?
post Apr 19, 2006 - 9:14 PM
could be a fuse...check all of the interior fuses, that might be an easy fix.
have you messed with anything behind it recently ? check to make sure it is plugged in properly (there are 2 for the unit and one for the AC).
post Apr 21, 2006 - 10:34 PM
BlackSTX
Joined May 17, '03
From Florence, KY
Replaced fuse twice, both times worked for a few minutes then blew the fuse again. What could be causing that?
post Apr 21, 2006 - 10:48 PM
Cutrara
Joined May 6, '05
From PA
Maybe a short. Something grounding out, possibly.
post Apr 25, 2006 - 10:06 AM
BlackSTX
Joined May 17, '03
From Florence, KY
QUOTE(Cutrara @ Apr 21, 2006 - 11:48 PM) [snapback]424657[/snapback]
It's the compressor locking up causing it to blow a fuse. I got it rebuilt for cheap about 3 years ago. I'm gonna have it fixed at the dealer this time.
Lo-Fi Version Time is now: June 26th, 2026 - 9:40 AM
