Apr 20, 2006 - 2:54 AM
![]() Enthusiast ![]() ![]() Joined Jun 28, '05 From MB, Canada Currently Offline Reputation: 1 (100%) |
Hey, i just installed my 7th gen short shifter, and im wondering if anybody did this without putting the spacers in?? I did it first without the spacers, and it worked fine, but 2nd gear was tough to get into. So i put the spacers in, found out the spacers nearest to the rear of the car do not fit, so i just replaced the spacers nearest the front of the car. When i had the metal spacers in, the shifting was not any better at all, worse infact, and it was very noisy. So i put the rubber spacers back into the rear but left the metal ones up front. It is less noisy, and 3rd and 4th are smoother than ever. But 1st and second are really rough, and when i move my shifter left to right, i hear what sounds like a rubbing noise, I can't see whats rubbing though. I think i was better off with the stock rubber spacers..... any thoughts/suggestions??
p.s. it is not the cable rubbing as i cut the assembly where the cable rubbed for digndug and others. This post has been edited by Tech9ine: Apr 20, 2006 - 2:57 AM |
Apr 20, 2006 - 3:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
The spacers should fit. Maybe you had them upside down or something like that? The spacers are needed, because you aren't so much taking size off the shifter, but more so moving the pivot point. If you don't have the spacers you will have a bad day.
And no, dont put the rubber ones back in, they give you new ones for a reason. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 20, 2006 - 7:13 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Put in all 4 metal spacers and cut the shifter assembly where the right cable rubs.
Apr 20, 2006 - 8:25 AM
the rubbing and toughness getting it into 1st and 2nd is the bottom of the shifter hitting the floor. If anything, use the metal spacers in the back and rubber in the front, but I reccomend using the metal all around.
Apr 20, 2006 - 11:39 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
yep, all 4 should fit
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Apr 21, 2006 - 1:03 AM
aha! i see, alright so the reason it lokoed like my metal spacers would not fit, was because i would put the spacer down and then put the assembly down then try to screw the bolt into the chasis through the spacer... but the spacer didnt quite align right as it is on a bit of a slant. so i got in there held the spacer in the hole from under the assembly, put the bolt through the spacer, then let the assembly down, and that made it so the spacer could not move down the slight slant and i managed to bolt it in. I also lubed it up alot more and the shifter now is working fine. Thanks guys.
Apr 22, 2006 - 8:42 PM
is there any shifter bushings for 94 celica st's?? i could sure use some.
This post has been edited by Tech9ine: Apr 22, 2006 - 8:45 PM |
| Lo-Fi Version | Time is now: July 7th, 2026 - 5:06 PM |
