Apr 20, 2006 - 9:18 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
Im not really sure where to post this, but i think it may be in the engine/transmission... but when we bought the 99 GT Convertible one the gas pedal on it is very stiff. I dont have this problem with my 94 st...and didnt know if this was just a GT problem or what. The gas pedal is almost stuck unless you push it really hard, which makes it almost impossible to idle at low RPMs (which we use for all the uphill driving around austin)... Is this something i can fix? I hope the explanation is clear enough.
Thanks in advance, Josh. This post has been edited by JFrost9: Apr 20, 2006 - 9:18 PM -------------------- ![]() I am now a part of the ihavemorethen16gc club! |
Apr 20, 2006 - 9:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
wd-40 is your friend.
just spray some on the hinge point, when the car is off, pump it a bit to work it in, let the car sit for a bit (10-15 minutes) start it up, and see if it changes nething. (that would be the easy fix) -------------------- ![]() Kawi Love |
Apr 21, 2006 - 1:20 AM
it could be a pinched throttle cable, check the cable as it runs from the engine and into the car and inside the car.
Apr 21, 2006 - 1:40 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
My guess is its gotta be a problem with the throttle cable. Make sure all cable is clean and not getting obstructed. Dont confuse it with the cruise control wire.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Apr 21, 2006 - 1:43 AM
Enthusiast ![]() Joined Aug 14, '04 Currently Offline Reputation: 0 (0%) |
I had the same problem and I just greased the hinges.
Apr 21, 2006 - 7:37 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Baltimore, MD Currently Offline Reputation: 1 (100%) |
I had a similar problem. My problem was on the throttle body end of the cable, the part that the cable pulls was hardly lubricated, I just sprayed some wd 40 on it and everything was fine.
Apr 21, 2006 - 8:02 AM
![]() Enthusiast ![]() Joined Sep 18, '05 From NW North Carolina Currently Offline Reputation: 4 (100%) |
QUOTE(bojangles_8686 @ Apr 21, 2006 - 8:37 AM) [snapback]424427[/snapback] I had a similar problem. My problem was on the throttle body end of the cable, the part that the cable pulls was hardly lubricated, I just sprayed some wd 40 on it and everything was fine. Had a similar problem with mine. I would check the throttle body first. The problem behind my throttle sticking was an uncovered/unfiltered hole in the bottom of my stock air box. It got the throttle body hinges kinda gummed up and a dealer charged like $10 to clean it out for me. When I installed the Ingen intake, I added a breather filter to keep this from happening again. -------------------- |
Apr 21, 2006 - 11:26 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
Easy enough to unhook the throttle cable at both ends, should slide back and forth in the housing very easily, sometimes the cable starts fraying and the strands catch in the cable housing, you can also work the throttle body and the gas pedal by hand with the cable unhooked to isolate trouble.
Apr 21, 2006 - 11:33 AM
Enthusiast ![]() Joined Feb 6, '06 From Salem, NH Currently Offline Reputation: 1 (100%) |
I had the same problem. For me there was a little rubber piece stuck on the throttle cable.
Apr 21, 2006 - 12:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
QUOTE(Killswitch @ Apr 21, 2006 - 9:33 AM) [snapback]424489[/snapback] I had the same problem. For me there was a little rubber piece stuck on the throttle cable. That's how I fixed mine too. |
May 1, 2006 - 10:47 PM
Enthusiast ![]() ![]() Joined Dec 26, '05 From So Cal Currently Offline Reputation: 1 (100%) |
I had a similar problem. Turns out that the intake valve in my throttle body was all gummed up. I just sprayed some carburetor cleaner in there and wiped out the gook, since then everything's fine.
May 1, 2006 - 10:56 PM
not to jack this but i had a scary moment where i was driving down my block, and i went to brake but the car was still revving high, i park it and its revving higher and im not pressing the gas. i open the hood and fiddle with the throttle cable and it went down to normal.
| Lo-Fi Version | Time is now: August 22nd, 2026 - 7:22 PM |
