Apr 21, 2006 - 12:29 PM
Enthusiast ![]() Joined Nov 21, '05 From Quebec Currently Offline Reputation: 0 (0%) |
This is part I can't identifie
what it is? I know it's have map sensor,ignitor and ecu (dont have pic for that) if Someone know some other part can I have need for swap in 5sfe car Tank you This post has been edited by 3rdgen3SGTE: Apr 21, 2006 - 2:10 PM -------------------- Celica GTS turbo 1994
3sgte genIII Ct20b |
Apr 21, 2006 - 12:30 PM
Fuel injector relay or fuel pump relay cant tell which. Whats the number on the back?
I'm not quite sure what your asking in your other question(s). This post has been edited by Supersprynt: Apr 21, 2006 - 12:31 PM -------------------- |
Apr 21, 2006 - 12:36 PM
I want know if I need other part for my swap QUOTE(Supersprynt @ Apr 21, 2006 - 12:30 PM) [snapback]424511[/snapback] Fuel injector relay or fuel pump relay cant tell which. Whats the number on the back? I'm not quite sure what your asking in your other question(s). I have two same thinks part so one with 2 wires and the other 5 wires I think is that fuel and injecteur resistor This post has been edited by 3rdgen3SGTE: Apr 21, 2006 - 12:38 PM -------------------- Celica GTS turbo 1994
Apr 21, 2006 - 2:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
the 5 wires is the fuel injector resistor pack, you NEED this, ive read on mr2oc and celicatech i think some people remove them, but DO NOT do it, its unsafe, im not sure why they do it but they are flirting with disaster.
the other one is fuel pump resistor pack which you do not need. |
Apr 21, 2006 - 2:57 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Last part is an idle control valve. Operates when you have the aircon running for example.
BTW, do you think you could post larger pics next time Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Apr 21, 2006 - 6:11 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
The two silver boxes: 2-wire is the fuel pump resistor, the 5-wire is for the injector resistors.
The third picture is your ignition coil (I think - the picture is unclear) The fourth picture is the air bypass for the air conditioning. It can be removed (and the assciated ports on the manifold and intercooler plugged) if you are removing your A/C. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Apr 21, 2006 - 8:47 PM
Tanks lots
It's my 3rd 3sgte engine that I buy and now need other one only for injector resistor pack if my 4th gen Map sensor fit on the 3rd gen engine. Or maybe some place for buy injector resistor pack I don't need so lot of spare part -------------------- Celica GTS turbo 1994
| Lo-Fi Version | Time is now: August 29th, 2026 - 3:42 PM |
