> AEM intake bypass installed!, joy
post Apr 22, 2006 - 3:41 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Since my intake sits literally on the plastic under-guard stuff underneath the car I decided it might be wise to get an intake bypass.. that and lowering the car soon..
Anyways, so I get home from work (11:30) and find the package on the kitchen table. Who wants to wait? Not me! So I go out to the garage and start disassembling the intake. I tossed the coupler from the TB to the intake arm, because it was ripped real good. Then I switched over the coupler from the middle of the arm to the top. When I took the coupler off the lower connection I found that there was a little bump in the metal, which wouldn't let the bypass go on, so I took a razor and shaved off a little of the rubber on the inner part of the bypass. I then put the bypass onto the lower arm and then tried to connect the two, which turned out to be impossible. With my intake how it is (see picture) The Distributor and the battery make a bottleneck in the passage of the intake, and guess what? The new filter needs to be right there. Couldn't do it. Tried running it above them, but hood barely wouldn't close. So now I am sitting in my garage. Pissed. I didn't want to go buy a pipe extension, and I wanted to install it...but no way to fit it.... WAIT! Why don't I move the battery over slightly and then try! SUCCESS! Tight fit, but its together. I didn't have my camera with me, but if anyone (I doubt) is interested in them, then I guess I will go take some. Until then, I am tired and I am going to pass out!
EDIT: ha, you guys might want the picture I refer to..
This post has been edited by 95CelicaST: Apr 22, 2006 - 3:45 AM
**** Photobucket
post Apr 23, 2006 - 2:27 AM
95CelicaST
Joined Feb 5, '05
Boo to all you people who look and no requests for pictures of my ingenious engineering skills (ha!).
**** Photobucket
post Apr 23, 2006 - 7:53 AM
klm317
Joined Feb 28, '06
From illinois
i'ld like to see a picture, i'm looking to put an intake on my 95 GT and need some ideas. so lets see it
post Apr 23, 2006 - 7:50 PM
jcbass7
Joined Apr 20, '06
From Florida
im not totally sure what this aem bypass thing is.. i have a short ram intake and don't have this thing on there.. could someome explain what it is and why i should go buy one?
post Apr 23, 2006 - 8:41 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
its for hydrolocking, if your car gets submerged in water it wont kill your car. if you have a short ram then you dont need it. its mainly for cold air intakes.
post Apr 24, 2006 - 12:46 AM
95CelicaST
Joined Feb 5, '05
^Basically.
My filter sits on the plastic flooring in the engine bay, and I am lowering my car soon.. so it will be even closer. All of that and I live in Washington.. where it rains 364 days a year.
EDIT: I don't know why this picture is so big, but there it is.
Before
After
This post has been edited by 95CelicaST: Apr 24, 2006 - 12:50 AM
**** Photobucket
post Apr 24, 2006 - 12:50 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
why didnt you just switch to a short ram, the bypass will just suck air from the engine bay all the time just like a short ram.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Apr 24, 2006 - 12:55 AM
95CelicaST
Joined Feb 5, '05
because it isn't just an open filter. Very little air will come through there as compared to my main filter, so I didn't feel like switching. Plus, my filter is a whole hell of a lot bigger, and it definately would not have fit between the distributor and the battery, and I'm not going to go get more piping.
**** Photobucket
post Apr 24, 2006 - 9:14 AM
LewFX
Joined Jan 28, '05
i agree with switching to a short or medium ram, as nice as cold air intakes sound the throttle response is too long and if it rains allot the air must be somewhat cool as is. altho i do like your setup and my c-one tower would look awesome in the bay!
post Apr 24, 2006 - 10:15 AM
95CelicaST
Joined Feb 5, '05
Agreed! why don't you just uh.... go ahead and pack it up and sent it off...
**** Photobucket
post Apr 24, 2006 - 10:17 AM
LewFX
Joined Jan 28, '05
post Apr 24, 2006 - 10:27 AM
95CelicaST
Joined Feb 5, '05
well i tried.....
**** Photobucket
post Apr 24, 2006 - 2:18 PM
tomazws
Joined Oct 30, '04
From So Cal
Does it really get cold air? I mean, your intake is between the hot hot Engine and the hot hot Radiator?!?!
post Apr 24, 2006 - 2:23 PM
95CelicaST
Joined Feb 5, '05
I believe so
**** Photobucket
post Apr 25, 2006 - 4:53 PM
tomazws
Joined Oct 30, '04
From So Cal
oh wow all the way at the bottom....
thats crazy
post Apr 26, 2006 - 1:44 AM
95CelicaST
Joined Feb 5, '05
thats crazy
**** Photobucket
Lo-Fi Version Time is now: June 7th, 2026 - 2:53 PM
