Apr 22, 2006 - 8:32 AM
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
Why do my fans come on when I turn the key on? 3rd gen int an st. I am sure I will have lots of stupid little questions, but I know you guys could probably point me in the right direction a little faster. thanks lance
Apr 22, 2006 - 2:22 PM
Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) |
mine does too...it stays on constantly till i take the key out. it doesnt bother me...should it? i can't see how it could be bad.
in for explaination edit: where are you in Ohio? This post has been edited by gtfc115: Apr 22, 2006 - 2:23 PM |
Apr 23, 2006 - 5:50 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
whoever did your wiring probably did it that way on purpose to prevent overheating. the only negative i see to that is that you don't need the fan unless you are not moving, thus when you are on the freeway it is taking electricity. but i don't think you should worry about it.
Apr 23, 2006 - 11:11 AM
could just wire up a switch if it bothers you...im too lazy
Apr 23, 2006 - 11:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
mine does the same thing
Apr 23, 2006 - 1:30 PM
there is a temp sensor on the radiator that controls when the fans come on. if you dont have the sensor connected, the fans stay on all the time. plug in the sensor and the problem will go away.
Apr 23, 2006 - 2:54 PM
QUOTE(lagos @ Apr 23, 2006 - 6:30 PM) [snapback]425165[/snapback] there is a temp sensor on the radiator that controls when the fans come on. if you dont have the sensor connected, the fans stay on all the time. plug in the sensor and the problem will go away. The sensor is pluged in.. must mean that it is bad. thanks lance |
| Lo-Fi Version | Time is now: August 28th, 2026 - 4:09 AM |
