Jun 5, 2003 - 4:36 PM
![]() Enthusiast ![]() Joined Mar 31, '03 From cary . north carolina Currently Offline Reputation: 2 (100%) |
how do I advance my timing.
Jun 5, 2003 - 4:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
loosen the distributor and rotate clockwise. its strongly recommended you use a timing light though, just so you don't advance so far you enduce ping. |
Jun 5, 2003 - 4:57 PM
hey doggy I havent had a chance to look but where is the distibutor location on st ?
Jun 6, 2003 - 6:28 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
look at the engine, it is on the right, where the plug wires are linked to.
There are 2 bolts under the distributor that u must loose. After that rotate the distributor and tight the bolts and u're done! |
Jun 7, 2003 - 10:53 AM
![]() Enthusiast ![]() Joined May 23, '03 From Illinois Currently Offline Reputation: 0 (0%) |
If you advance the timing do you have to use higher octane fuel?
Jun 7, 2003 - 11:59 AM
depending on how far you advance. you should be okay up to 14 degrees. personally I would run high octane over 12 but mb thats just me, don't want to get ping ya know. |
Jun 7, 2003 - 7:48 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
When you rotate your distributor, I believe you rotate to the right. I would definately use higher octane. After I advanced my timing, I ran regular and is ran like **** and my engine started to knock. After I put in higher octance, the car ran better.
Jun 8, 2003 - 9:24 PM
don't u have to use higher octance gas if you advance the timing?
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:09 AM |
