Apr 25, 2006 - 12:36 PM
QUOTE(presure2 @ Apr 25, 2006 - 6:36 AM) [snapback]426150[/snapback] QUOTE(lagos @ Apr 25, 2006 - 2:19 AM) [snapback]426106[/snapback] QUOTE(defgeph @ Apr 25, 2006 - 2:14 AM) [snapback]426104[/snapback] QUOTE(lagos @ Apr 25, 2006 - 2:12 AM) [snapback]426102[/snapback] nice numbers and VERY nice air/fuel curve. i wonder how much your new fuel rail has to do with that? ps. you need an mbc..lol I really wish now that I did a before and after with the rail. The MBC sounds tempting change your plugs and check them after letting the car idle for a few minutes. if they are not crazy black (like they normally are) ,then i would be willing to bet that the rail has something to do with the a/f curve. the rail has nothing to do with the curve. all the rail does is lower the pressure drop across the rail. if anything, it'd make it richer. its all in that RC ecu. i remember ChrisD from ctech telling me that once he installed an upgraded fuel rail, his spark plugs no longer fouled up like the do on every swap. so thats why i was thinking it might have something to do with it. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 25, 2006 - 12:37 PM
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
@ 20psi I thought my wheels were going to fly off my car heh.
-------------------- BANNED!
Apr 25, 2006 - 12:38 PM
QUOTE(burneeed @ Apr 25, 2006 - 1:37 PM) [snapback]426261[/snapback] @ 20psi I thought my wheels were going to fly off my car heh. you really should be running any more then 15 on a ct26. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 25, 2006 - 1:15 PM
time for a turbo upgrade
gt35r should do the trick nice power -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Apr 25, 2006 - 2:24 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
QUOTE(lagos @ Apr 25, 2006 - 1:36 PM) [snapback]426260[/snapback] i remember ChrisD from ctech telling me that once he installed an upgraded fuel rail, his spark plugs no longer fouled up like the do on every swap. so thats why i was thinking it might have something to do with it. I'm not doubting ChrisD, but I have never fouled out one plug with my swap. So, I dont really understand what you mean ? Did you ever foul out plugs with yours ? Thanks for all the complements guys. BTW GT35R is a little to much for me -------------------- ![]() I will return one day. |
Apr 25, 2006 - 2:34 PM
if you put in fresh spark plugs into a 3s, and just let it idle (not even drive or boost it) for about 2minutes, then take them out, they will be totally black. chrisD said this dosnt happen with an upgraded fuel rail .
Apr 25, 2006 - 2:43 PM
QUOTE(97sccelica @ Apr 25, 2006 - 2:15 PM) [snapback]426284[/snapback] time for a turbo upgrade gt35r should do the trick nice power T04E 46T very nice run jeff and great video that RC is defenitly beating the expectations |
Apr 25, 2006 - 3:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
very nice numbers i cant wait to getmine on the dyno
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 25, 2006 - 4:56 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
QUOTE(playr158 @ Apr 25, 2006 - 7:43 PM) [snapback]426314[/snapback] QUOTE(97sccelica @ Apr 25, 2006 - 2:15 PM) [snapback]426284[/snapback] time for a turbo upgrade gt35r should do the trick nice power T04E 46T very nice run jeff and great video that RC is defenitly beating the expectations ill be posting dyno numbers with that turbo sometime in the summer |
Apr 25, 2006 - 4:57 PM
actually those are REALLY great #s
we just NEED to get that boost controler set PROPERLY. -------------------- |
Apr 28, 2006 - 9:52 AM
just for comparisons sake, heres an overlay of jeffs best run VS a bone stock usdm 95mr2T
i think jeff has a slight advantage...
Apr 28, 2006 - 11:05 AM
I said whoa! When I first saw that run file, the difference is like night and day.
Apr 28, 2006 - 4:54 PM
now look at the mr2s "tuning". dont you think there is something wrong with that? i cant understand how toyota could tune a car off the scale ritch and sell it like that. there has to be some type of issue going on. that car looks like it has no factory tuning at all.
Apr 28, 2006 - 7:40 PM
actually, art, thats pretty typical of what you see outta a usdm 3sgte.
that specific dyno chart is one that is used all over mr2oc, and was given to me by ken blake, as refrence for my runs. -------------------- Former Team 5SFTE pro member ;)
Apr 28, 2006 - 7:44 PM
heres a copy past from KO racings website, its a street brawler VS stock setup, stock is the red graph, you can see its virtually the same as the one i posted.
Apr 28, 2006 - 10:06 PM
what im tring to figure out, is why is it off the chart ritch? whats the problem thats going on here? is it the afm flapper door? is it from an upgraded fuel pump? could the factory ecu tuning be that horrible? i cant imagine the toyota engineers tuning the motor on a bench dyno and making it that crazy ritch. if anything they would want to lean it out so that they would sell more cars by being able to post a better mpg number. it almost seems like there is a common problem with all the cars, that toyota didnt intend to happen.
This post has been edited by lagos: Apr 29, 2006 - 12:35 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 28, 2006 - 10:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Yea, the A/F on the MR2 is wacky. Maybe Toyota just wanted to be way over-safe on the motor, but thats just crazy rich.
And Jeff, thats a beautiful dyno run. That thing really pulls now, my personal a$$ dyno agrees with those numbers as well. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Apr 28, 2006 - 11:31 PM
Thanks Corey, anytime you wanna chill gimmie a call.
Apr 29, 2006 - 12:38 AM
Anytime. I really want to see what the thing is like in the day, I think i've only ever riden in the RC at night. We're stealth like that.
I'm going to see if the weather is looking alright for tommorrow, I'll call you. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Apr 29, 2006 - 5:55 AM
QUOTE(lagos @ Apr 28, 2006 - 11:06 PM) [snapback]427743[/snapback] what im tring to figure out, is why is it off the chart ritch? whats the problem thats going on here? is it the afm flapper door? is it from an upgraded fuel pump? could the factory ecu tuning be that horrible? i cant imagine the toyota engineers tuning the motor on a bench dyno and making it that crazy ritch. if anything they would want to lean it out so that they would sell more cars by being able to post a better mpg number. it almost seems like there is a common problem with all the cars, that toyota didnt intend to happen. there IS no problem, art. heres ANOTHER....this time from celicatech...we all know the stock ecu is stupid rich from the factory...why are you denying it now? mods at the time: 2.5" exhaust w/ gutted cat 3" DIY intake tyfoon motorsports BOV on tmic 11psi
| Lo-Fi Version | Time is now: August 24th, 2026 - 11:21 AM |
