Apr 28, 2006 - 4:41 PM
Enthusiast ![]() ![]() Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
So, today i decided i was going to give my trunk a good cleaning. I vaccumed and scotch guarded the flooring then pulled it up to discover a disaster! The spare tried wasnt not fixed in place, it was flat, and the grime was so thick.. uhh... it was just really thick
Angle 1 ![]() Angle 2 ![]() A) (possibly holds down spare) B) Tail light peg cover on back panel C) Back panel in trunk D) Back seat rail cover E) ??? F) Panel cover from trunk This post has been edited by phonex98: Apr 28, 2006 - 5:39 PM -------------------- ----- '94 ST hatch --- Yellow ----- |
Apr 28, 2006 - 4:57 PM
Enthusiast ![]() Joined Feb 21, '06 From MD/NY Currently Offline Reputation: 0 (0%) |
dont know the technical terms but c is for the back panel of your trunk
d covers the back of your seat rails f is used to hold on various panels in the trunk not 100% sure cause of the angles of the pic but a might be used to hold down your spare but cant really tell never seen b or e before though... really looks like someone tried to run wires for subs (or had some other reason for takign all that paneling off) tried to put it back together and missed alot of parts not knowing where they went and just threw em in the trunk |
Apr 28, 2006 - 5:38 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
B is just another cover for the holes where the tailight pegs are...along that back panel there. Ive never seen E either...
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
Thanks for your replies. Im heading out of town tonight so i wont hav a chance to test those peices, but ill try them tomorrow! Also.. ive had a few suggestions that perhaps E is from a golf bag, which certainly is possible. Thanks
Apr 28, 2006 - 5:40 PM
a: goes on top of the spare, a wing nut holds it down
b: no clue c: they go on the back of the back panel covering the bolts d: back seat rail cover? sure okay e: no clue f: those hold the carpet part to the top of the car, theres 3 of em in the upper rear area. -------------------- ![]() |
Apr 28, 2006 - 6:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
I know what E is! brings me back to my band days.. when i played the bass guitar.
E: microphone clip. (screws onto the top of a microphone stand and the mic clips into that groove. |
Apr 28, 2006 - 9:25 PM
most of you are correct.
a hold spare down b cover on the inner rear trunk plastic c plastic nuts that help hold that same plastic secure d seat rail cover (pull your seat forward and look behind it for the rail, that is a cover) e not 6gc related f those are kinda common, there are some behind your rear strut covers, holding more plastics secure if you want pics as to where anything goes, let me know -------------------- |
Apr 28, 2006 - 11:12 PM
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) |
my eye went right to e. as jcbass said, it's the part that holds a microphone to a mic-stand.
Apr 28, 2006 - 11:29 PM
Enthusiast ![]() ![]() Joined Jan 6, '06 From Tennessee Currently Offline Reputation: 0 (0%) |
Yeah. I was pretty sure E was a mic clip too :-p
Apr 29, 2006 - 6:21 PM
Wow, I just spent about an hour tring to put all these peices in... how you guys could tell me where they went form that photo is amazing
A) Tried placing that on/around/near spare... couldnt for the life of me figure out how it attaches. Also... the bottom of it appears to actually go into a hole... The has a round head, and skinnier body, implying you push it into a whole, and it doesnt come out. B) I put in C in the holes.. they worked awesome... but couldnt find a place for B ? D) I see the seat rail cover on the passenger side, and the drives side IS missing one... but this peice is a much different shape than the passenger side and couldnt get it to affix in any way. This post has been edited by phonex98: Apr 29, 2006 - 6:25 PM -------------------- ----- '94 ST hatch --- Yellow ----- |
Apr 29, 2006 - 6:31 PM
for the spare, there should be a long screw type that goes thru the spare, thru that wood piece. then have A go on top that and you hold it down with a wing nut or a nut.
This post has been edited by LewFX: Apr 29, 2006 - 6:32 PM -------------------- ![]() |
Apr 29, 2006 - 7:24 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
(A) is a body plug. youll have to remove the spare tire and look for a large hole. Or possibly under the back seat bottom cusion. (D) Is a front seat hold down bolt cover. should go in the rear of the seat. There are only 4 bolts per seat. (B) is a interior cover screw hole cover. cant tell you without looking at my car. Ill look later when its light outside.
Apr 30, 2006 - 2:34 AM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
QUOTE(phonex98 @ Apr 30, 2006 - 11:21 AM) [snapback]427967[/snapback] D) I see the seat rail cover on the passenger side, and the drives side IS missing one... but this peice is a much different shape than the passenger side and couldnt get it to affix in any way. There are two rails for each seat. total 4 covers. 2 of each kind. I think yours is actually the drivers side next to the door one. This post has been edited by soven: Apr 30, 2006 - 2:35 AM |
Apr 30, 2006 - 10:10 PM
QUOTE(soven @ Apr 30, 2006 - 12:34 AM) [snapback]428099[/snapback] I think yours is actually the drivers side next to the door one. Bingo! haha... i made the mistake of thinking the curve in the peice made contact with the curve on the seat... Wrong! But i've got it now, thanks everyone -------------------- ----- '94 ST hatch --- Yellow ----- |
May 1, 2006 - 9:46 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
E looks like a microphone hold for a microphone stand... I dont believe its celica related.
May 5, 2006 - 11:43 AM
QUOTE(DmVinny @ May 1, 2006 - 9:46 PM) [snapback]428838[/snapback] E looks like a microphone hold for a microphone stand... I dont believe its celica related. Well it could have been some custom peice, you know like an on the road karaoke machine, then you could drive and sing without having to hold the mic |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 5:24 PM |
