May 1, 2006 - 10:51 PM
with std correction, i made
229HP and 240TQ with SAE crrection i made 222hp 234tq at 12-13psi ...with lots of issues..... here is a video from the dyno http://download.yousendit.com/D176956C4A979DBC so i finally went to the dyno for the first time ever. on my 1st run i got a shocking surprise. the car was very lean and there was a huge drop in the power curve. what the hell happened? right before the dyno, i installed some Bosch coper plugs. the store was out of NGK and i figured, it would probably be fine. boy was i wrong. can someone explain to me how sparkplugs can make my car run lean like that? lucky for me, the dyno owner is an mr2 owner as well. he had a fresh set of NGKs so we quickly droped them in. it seemed to cure the problem. the 2nd run did a lot better, and with the 3rd and 4th run the car was getting ritcher and ritcher, to where it should be. then i noticed another problem. before going to the dyno, i was hitting 15psi on the street. problem is, when i got on the dyno all i was seeing was about 12 maybe 13psi, and it would start to drop off to around 10psi in the higher rpm range. this was a problem i never noticed in my car before. the only thing i can think of is that my car has a boost leak, or the mbc is not doing its job. here is the 1st run. i was shocked when i saw that. ![]() this is the 2nd run . you can see the a/f start to get better as well as the power curve. ![]() finally this is the 4th run. you can see the a/f is much better
This post has been edited by lagos: May 2, 2006 - 11:40 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos Went to the Dyno : what the hell happened? May 1, 2006 - 10:51 PM
jgreening A few observations:
1. The first run shows massiv... May 1, 2006 - 11:03 PM
x_itchy_b_x sweet man, nice numbers! i just turned up my b... May 1, 2006 - 11:05 PM
lagos QUOTE(jgreening @ May 2, 2006 - 12:0... May 1, 2006 - 11:08 PM
lagos and it looks like i was wrong about the fuel rail,... May 1, 2006 - 11:23 PM
defgeph Its about time!
Nice numbers. I think you ... May 2, 2006 - 12:23 AM
lagos we did the runs one after the next, because the wh... May 2, 2006 - 12:32 AM
defgeph You know whats funny.
I have an EBC, I'm thin... May 2, 2006 - 12:37 AM
lagos yeah, i really wanted them to log boost, but they ... May 2, 2006 - 12:40 AM
defgeph I just need like 20 minutes devoted to the control... May 2, 2006 - 12:50 AM
brianforster good numbers, makes me scared about my EBC though ... May 2, 2006 - 1:16 AM
lagos and if u look at my video.... i need to redo my mo... May 2, 2006 - 1:25 AM
BLADDER_MASTER d00d, if it's one thing I've learned from ... May 2, 2006 - 1:34 AM
presure2 good job art,
jay hit the nail right on hte head.... May 2, 2006 - 6:57 AM
BBoYRuGGeD wow nice numbers art and thank god i didnt pick... May 2, 2006 - 7:32 AM
OOBE Lagos, your curve needs some serious Anti-Aliasing... May 2, 2006 - 7:49 AM
Supersprynt QUOTE(lagos @ May 2, 2006 - 2:25 AM)... May 2, 2006 - 10:36 AM
playr158 QUOTE(Supersprynt @ May 2, 2006 - 11... May 2, 2006 - 10:40 AM
lagos so it seems i made more power then i thought. ma... May 2, 2006 - 11:31 AM
lagos here is an exported view of the last run. if you ... May 2, 2006 - 4:04 PM
presure2 QUOTE(lagos @ May 2, 2006 - 5:04 PM)... May 2, 2006 - 5:38 PM
dustin15brown good numbers art May 2, 2006 - 4:46 PM
eggman40 How much did the tuning session run you? May 2, 2006 - 5:16 PM
lagos QUOTE(eggman40 @ May 2, 2006 - 6:16 ... May 2, 2006 - 5:26 PM
lagos i would say that you did a really good job with ju... May 2, 2006 - 6:36 PM
presure2 Dynojet Research Inc.
Run Name: C:\DynoRuns... May 3, 2006 - 6:41 PM
lagos thats just nuts
now we know why the jdm ecu gains... May 3, 2006 - 6:42 PM
Supersprynt Whoa. May 3, 2006 - 7:22 PM
lagos can a wideband even real less then 10:1 ? May 3, 2006 - 7:51 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 24th, 2026 - 4:58 PM |
