> HELP !!! - Trying to reset my ECU
post May 2, 2006 - 7:08 PM
PLA-04Y
Joined May 2, '06
From Australia Sydney NSW
Hi Guys, anyone assist me with reseting my ECU ??? I have a Toyota Celica ZR 1996 (3S-FE) and cannot remove my EFI fuse. I have been janking on it all night but it will not come out. frown.gif
post May 2, 2006 - 7:11 PM
pure_dx
Joined Dec 28, '05
From USA
just take off the terminals to your battery, then you wont have to deal with fuses', ;p
post May 2, 2006 - 7:13 PM
PLA-04Y
Joined May 2, '06
Will this do the same as removing the Hazard, EFI and ECU fuses for 10min to reset my ECU?
post May 2, 2006 - 7:24 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
thats for a 3sgte but you can relate it to any ecu really.
post May 2, 2006 - 7:36 PM
PLA-04Y
Joined May 2, '06
See what I am trying to do is "Resetting your Air/Fuel Mixture Ratio" from the 'How to' section of www.6gc.net. The instructions specifially say that the Hazard, EFI and ECU fuses need to be removed for 1min then let the car run for 10min to reset.
see the efi fuse just wount budge.
This post has been edited by PLA-04Y: May 2, 2006 - 7:37 PM
post May 3, 2006 - 4:52 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I dont think you've a 3sfe.
Its more like a 5sfe.
6GC 4 Life Baby!!!
post May 3, 2006 - 8:41 AM
PLA-04Y
Joined May 2, '06
QUOTE(CelicaZR @ May 3, 2006 - 4:52 AM) [snapback]429411[/snapback]
why?
post May 3, 2006 - 9:29 AM
CelicaZR
Joined Mar 25, '05
6GC 4 Life Baby!!!
post May 3, 2006 - 9:45 AM
celi94
From Belgium
Clearing Trouble Codes
After repair of the circuit, the diagnostic code(s) must be removed from the ECM memory. With the ignition turned OFF, remove the 15 amp EFI fuse for 30 seconds or more. Once the time period has been observed, reinstall the fuse and check for normal code output.
Fig. 17: Removing the EFI fuse will clear the trouble codes retained in the ECM
If the diagnostic code is not erased, it will be retained by the ECM and appear along with a new code in event of future trouble.
Cancellation of the trouble code can also be accomplished by disconnecting the negative battery cable. However, disconnecting the battery cable will erase the other memory systems including the clock and radio settings. If this method is used, always reset these components once the trouble code has been erased.
chilton online
post May 4, 2006 - 2:54 AM
PLA-04Y
Joined May 2, '06
QUOTE(CelicaZR @ May 3, 2006 - 9:29 AM) [snapback]429443[/snapback]
Nice Car ! Where did you get the Varis Arising II Kit, JDM Projectors Headlights, JDM Tails from? Hot. Definitely Hot.
QUOTE(celi94 @ May 3, 2006 - 9:45 AM) [snapback]429449[/snapback]
chilton online
So.... disconnecting the negative battery will reset my ECM so that my Fuel to Air Ratio is reset? Thanks
post May 4, 2006 - 3:07 AM
CelicaZR
Joined Mar 25, '05
QUOTE(PLA-04Y @ May 4, 2006 - 5:54 PM) [snapback]429915[/snapback]
Your one is not bad too.
Where about are you in Sydney?
6GC 4 Life Baby!!!
post May 4, 2006 - 4:38 AM
PLA-04Y
Joined May 2, '06
QUOTE(CelicaZR @ May 4, 2006 - 3:07 AM) [snapback]429918[/snapback]
Macarthur, you? Can your friend get more JDM gear?
post May 4, 2006 - 4:49 AM
CelicaZR
Joined Mar 25, '05
Yea, of course!
PM what you want and I'll let you know.
6GC 4 Life Baby!!!
post May 4, 2006 - 5:01 AM
PLA-04Y
Joined May 2, '06
Lo-Fi Version Time is now: May 16th, 2026 - 10:38 PM
