May 3, 2006 - 11:46 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) |
yea i can't get it out how did you take it out?
May 3, 2006 - 11:54 AM
You're talking about the 15amp mini blade fuse, right? It just pulls right out.
May 3, 2006 - 12:01 PM
Enthusiast ![]() ![]() Joined Jan 27, '05 From Rockville, MD Currently Offline Reputation: 1 (100%) |
Use the fuse puller
May 3, 2006 - 12:02 PM
that big black one on the bottom left corner.i pulled to the ecu,and that hazord one. i just need that efi out. now thinking about it maybe im not strong enoght to pull it out
This post has been edited by pandakid: May 3, 2006 - 12:04 PM -------------------- |
May 3, 2006 - 12:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
There's one fuse that is bolted in, if you're having a hard time pulling it out, it might be the one. I had to remove the top half of the fuse box to get to it.
May 3, 2006 - 12:06 PM
maybe i'll just take off my negative terminal, sorry i just got my sp2 greddy sometime ago. i forgot to reset the computer. thanks for the repleys so fast .
This post has been edited by pandakid: May 3, 2006 - 12:07 PM -------------------- |
May 3, 2006 - 12:21 PM
The fuse I'm talking about that's bolted down looks like the green one in the top left corner. I literally shattered my fuse apart till I figured out that it was bolted down. I mean who knew there are fuses that are screwed in, I thought all fuses you can just pull right out.
| Lo-Fi Version | Time is now: September 11th, 2026 - 11:04 AM |
