May 3, 2006 - 10:17 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
I was told that the engine 4AGE 20 VALVE with FORGED TURBO PISTONS 8.5:1 will bolt on my 1995 ST without mods ??? I don't know about the topic so I would like some of you with more acknowlegde to let me know if this is true on not ???
This post has been edited by Culpable04: May 4, 2006 - 10:55 AM -------------------- ![]() |
May 3, 2006 - 10:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
QUOTE(Culpable04 @ May 3, 2006 - 11:17 PM) [snapback]429812[/snapback] I was told that the 4AGE 20 VALVE FORGED TURBO PISTONS 8.5:1 will bolt on my 1995 ST without mods ??? I don't know about the topic so I would like some of you with more acknowlegde to let me know if this is true on not ??? by on u mean into? if u mean put the whole engine in yes,....direct bolt in. But if your talking about swaping pistons, i highly doubt it. -------------------- ![]() Kawi Love |
May 3, 2006 - 10:26 PM
will the 4age pistons fit into a 7afe.....short answer yes they will
BUT you need to modify the wrist pin/con rod because 7afe = locking 4age = full foating... why do you need to change pistons anyways? |
May 4, 2006 - 12:32 AM
8:5:1 20V pistons aren't gonna make that compression in a 7AFE. Piston's are hardly "bolt-on"... in fact, there aren't any bolts.
-------------------- "It's ok to be naked girl... I'm an artist!"
May 4, 2006 - 12:47 AM
Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
isn't the 20v 5 valves per piston, your 7afe only has 4 per piston,..........unless you're talking about head swapping?
This post has been edited by pure_dx: May 4, 2006 - 12:48 AM |
May 4, 2006 - 12:49 AM
wat do valves have to do with the pistons?
if you do a search there is a pretty lengthy discussion on this topic This post has been edited by playr158: May 4, 2006 - 12:49 AM |
May 4, 2006 - 2:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
QUOTE(pure_dx @ May 3, 2006 - 10:47 PM) [snapback]429883[/snapback] isn't the 20v 5 valves per piston, your 7afe only has 4 per piston,..........unless you're talking about head swapping? QUOTE(playr158 @ May 3, 2006 - 10:49 PM) [snapback]429884[/snapback] wat do valves have to do with the pistons? if you do a search there is a pretty lengthy discussion on this topic He mentioned 20 valve because it helps identify what generation 4age engine. He wants to take the pistons from the 4age (20 valve) and put them into the 7afe. From what I remember readying is, yes the pistons will fit on the 7afe rods BUT it will increase compression of the 7afe and it will not float on the rods properly. But it is believed once the engine heats up the pistons will float easier. |
May 4, 2006 - 8:43 AM
Sorry, I just copy the article as appears on the email that my friend sent me.
I meant the whole 4AGE engine and It has 20 VALVE FORGED TURBO PISTONS 8.5:1. I think someone here already told me it a direct bolt on engine, I just wanna make sure before I make any investment. This post has been edited by Culpable04: May 4, 2006 - 9:00 AM -------------------- ![]() |
May 4, 2006 - 8:46 AM
QUOTE(Culpable04 @ May 4, 2006 - 9:43 AM) [snapback]429986[/snapback] Sorry, I just copy the article as appears on the email that my friend sent me. I meant the whole 4AGE enginge and It has 20 VALVE FORGED TURBO PISTONS 8.5:1. I think someone here already told me it a bolt on engine, so If it is what would be the benefits ? will my car be a little faster with this engine than with the 7AFE ? and which engine would be better choice if I decided to put a turbo in my car ? yes the motor is a direct drop in...minus wiring harness. and the 4age with the forged pistons is a better choice to turbo. -------------------- ![]() Kawi Love |
May 4, 2006 - 9:19 AM
i meant the grooves, there are four grooves for the 16v while the 20v has 5 grooves
This post has been edited by pure_dx: May 4, 2006 - 9:19 AM |
May 4, 2006 - 9:27 AM
QUOTE(pure_dx @ May 4, 2006 - 10:19 AM) [snapback]429998[/snapback] i meant the grooves, there are four grooves for the 16v while the 20v has 5 grooves ![]() hes talking motor swap tho.....he just worded it poorly (not ragging on u, just confused us) -------------------- ![]() Kawi Love |
May 4, 2006 - 9:41 AM
sorry guys for confused you, I was tired last night when I post this.
May 4, 2006 - 10:57 AM
QUOTE(Hanyo @ May 4, 2006 - 3:21 AM) [snapback]429908[/snapback] QUOTE(pure_dx @ May 3, 2006 - 10:47 PM) [snapback]429883[/snapback] isn't the 20v 5 valves per piston, your 7afe only has 4 per piston,..........unless you're talking about head swapping? QUOTE(playr158 @ May 3, 2006 - 10:49 PM) [snapback]429884[/snapback] wat do valves have to do with the pistons? if you do a search there is a pretty lengthy discussion on this topic He mentioned 20 valve because it helps identify what generation 4age engine. He wants to take the pistons from the 4age (20 valve) and put them into the 7afe. From what I remember readying is, yes the pistons will fit on the 7afe rods BUT it will increase compression of the 7afe and it will not float on the rods properly. But it is believed once the engine heats up the pistons will float easier. if you read the 7afte sticky (on compressor maps and ect.) you'll see a section on the 4ag(z)e piston and your right they do increase compression to about 11.XX:1 in a 7afe motor which can be helped with a 2mm headgasket but IS NOT the best way to do it. and i highly doubt the warming of the motor will help piston float cause the rod also needs to be machined for an oil passage i believe. Doggy tried it...its a no go.. the best way if you want forged pistons in a 7afe is to have ARIAS, CP, JE or WISECO make you a custom set probably around 800$ or so |
May 4, 2006 - 11:07 AM
ok, so will the 4age engine bolt in my stock 1995 ST ??? what would be the changes needed to get this to work ???
May 4, 2006 - 11:08 AM
it will bolt in but you'll need to rewire..
May 4, 2006 - 11:15 AM
that's it. No new tranny ??
no major changes ? just rewire ? if it's just that I'll do it. I have a friend who can help me on that -------------------- ![]() |
May 4, 2006 - 12:10 PM
QUOTE(Culpable04 @ May 4, 2006 - 12:15 PM) [snapback]430049[/snapback] that's it. No new tranny ?? no major changes ? just rewire ? if it's just that I'll do it. I have a friend who can help me on that nothing just "drops in" or " bolts on ". its a custom swap, plain and simple. if you never did a swap, its going to be a lot of work and research to make it all work right. yes, the motor fits, but the wiring harness needs to be redone, and you have to spend some time working out bugs to make things run right. do as much research as you can before you start your project. if you dont, youll regret it later. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 4, 2006 - 12:19 PM
Ok. I'm not planing on doing it myself for different reasons.
I don't have a garage I don't have much free time but I have a friend that owns a shop he's very good mechanic and I talked to him about it he said that If I get the diagrams he may do it for me. So I'll keep doing research 'till I feel I have as much info as possible. if some of you guys have anything that can be help PLZ send it to me. -------------------- ![]() |
May 4, 2006 - 12:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
ok i know were not talking about the 7agte because in this post alone there is alot of wrong info
the compression the 4agze pistons 8.0:1 (i think)got 11.0:1 compression which was 4agze pistons on a 7afe bottom and a 7afe head now 4agze pistons in a 7afe with 4agze pistons and 4agze head compression still increase but only a little i have documented this from my set up now on the 20v motor swap+ turbo+ piston/internal work if your on a budget i would go 4agze instead then turbo -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 4, 2006 - 1:39 PM
I'm not planning turbo
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:57 PM |
