> swap officially finished! (but still has minor probs), i just drove it.. WOOOO HOOO!
post May 6, 2006 - 6:31 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok guys, i consider my swap FINISHED now because i just drove it around the block, however there are some minor problems i noticed during the test drive
first it idled about 1800 rpms, then after driving it it jumped up to 3000
my boost gauge reads 20 vac at idle so i assume no vacuum leaks
my power steering doesnt work, this confuses me because everything is hooked up
its hard to get it into gear, in fact when i first started it it would not go into gear, then it ended up going into reverse with some force (no grinding though) the car would lurch forward when trying to go into first and reverse when trying to go into reverse. my friend told me to re-bleed the clutch but before i went to do that i went for one more try and it finally went in, the shifting seems to get smoother the more i play with it so maybe it has something to do with the tranny being sitting bone dry for the past few months?
at idle my motor shakes a bit, and by a bit i mean that even with my not so vast experience with cars i know it should not do this.
btw tomorrow i will have pics and vids of everything, and ill start a before and after thread!
edit: jeff, how do you drive withot power steering man, i could hardly reverse into the driveway!
This post has been edited by brianforster: May 6, 2006 - 6:34 PM
- brianforster   swap officially finished! (but still has minor probs)   May 6, 2006 - 6:31 PM
- - playr158   make sure your powersteering lines are in the righ...   May 6, 2006 - 7:49 PM
- - brianforster   power steering is a leak in the high pressure line...   May 6, 2006 - 7:57 PM
- - brianforster   update: on a cold start it idles at about 2000 the...   May 6, 2006 - 9:04 PM
- - lagos   hey...noticed you called... i was out and didnt ha...   May 6, 2006 - 9:20 PM
- - brianforster   front and rear mounts are new though and those are...   May 6, 2006 - 9:35 PM
- - lagos   if they are new, then they should be ok. get a v...   May 6, 2006 - 9:38 PM
- - brianforster   also i found out the st radiator does not have a c...   May 6, 2006 - 9:46 PM
- - bigal004321   Nice job with the swap,,and congrats on the first ...   May 6, 2006 - 9:50 PM
- - lagos   QUOTE(brianforster @ May 6, 2006 - 10...   May 6, 2006 - 9:53 PM
- - defgeph   Congrats man. You get used to no power steering. ...   May 6, 2006 - 11:38 PM
- - x_itchy_b_x   congrats man!   May 7, 2006 - 12:25 AM
- - CelicaZR   Congrat man You've definitely come a long wa...   May 7, 2006 - 3:28 AM
- - brianforster   well today i put better gas in it and got some vid...   May 7, 2006 - 3:09 PM
|- - Chanh55   QUOTE(brianforster @ May 7, 2006 - 1...   May 7, 2006 - 3:25 PM
- - brianforster   can someone get me a pic of this screw? because on...   May 7, 2006 - 3:40 PM
|- - Chanh55   QUOTE(brianforster @ May 7, 2006 - 1...   May 7, 2006 - 3:49 PM
- - brianforster   also with the hood down after like 5 min of runnin...   May 7, 2006 - 3:44 PM
- - bojangles_8686   Ok here are the pics and videos from today.... ...   May 7, 2006 - 5:20 PM
- - jcbass7   not sure if this would be true, but maybe the hood...   May 7, 2006 - 5:52 PM
- - Hanyo   did you cover that hole on your down pipe? Is your...   May 7, 2006 - 6:32 PM
- - jcbass7   oh yea hanyo has a good point. If that hole isn...   May 7, 2006 - 6:49 PM
- - playr158   didn't i say you needed to close that o2 senso...   May 7, 2006 - 7:41 PM
- - BBoYRuGGeD   congrats on the swap man! hope you get all...   May 7, 2006 - 7:56 PM
- - lagos   QUOTEit gets hottest right over the tubular manifo...   May 7, 2006 - 7:58 PM
- - LewFX   ill compress the vid   May 7, 2006 - 8:19 PM
- - brianforster   if you notice both of the studs are broken on that...   May 7, 2006 - 9:40 PM
- - lagos   you can keep it where it is and wrap it with exhau...   May 8, 2006 - 12:24 AM
- - f1yen   [font=Tahoma]so is your car still idling high?, be...   May 9, 2006 - 9:29 PM
- - playr158   QUOTE(f1yen @ May 9, 2006 - 10:29 PM...   May 10, 2006 - 12:32 AM
- - brianforster   plus 2nd gen engine will not run without the AFM i...   May 10, 2006 - 11:04 AM
- - easternpiro1   good job bryan!! im glad everything worked...   May 10, 2006 - 12:43 PM
- - brianforster   it ended up being the throttle cable was too tight...   May 12, 2006 - 7:47 PM
- - morbiddelusions   lookin good   May 12, 2006 - 10:02 PM
- - lagos   the temp gauge should sit around the middle when w...   May 12, 2006 - 10:19 PM
- - brianforster   what needs to be replaced the gauge or the thermos...   May 13, 2006 - 12:18 AM
- - lagos   QUOTE(brianforster @ May 13, 2006 - 1...   May 13, 2006 - 12:57 AM
- - brianforster   how long should it take to reach the center?   May 13, 2006 - 9:08 AM
- - Rjb23   Depends when I first did my swap it took for ever ...   May 13, 2006 - 12:31 PM
- - BBoYRuGGeD   ^^^ yap same...about 5 min or less with mine on a ...   May 13, 2006 - 2:01 PM
- - DG_Performance   i highly recomend the trd lower thermostat for bet...   May 15, 2006 - 8:17 AM
Lo-Fi Version Time is now: August 26th, 2026 - 7:26 PM
