May 7, 2006 - 11:46 AM
Enthusiast ![]() ![]() Joined Apr 4, '06 From Minnesota Currently Offline Reputation: -1 (0%) |
my gauge cluster isn't working no more. i took out my white face and now the pins wouldn't move? anyone know why? help fast! thanks
This post has been edited by fastcelica20: May 9, 2006 - 7:54 PM -------------------- ![]() |
fastcelica20 Interior Lights All DEAD! May 7, 2006 - 11:46 AM
team_omega did you check your connector that connects to the ... May 7, 2006 - 1:29 PM
fastcelica20 QUOTE(team_omega @ May 7, 2006 - 1:2... May 7, 2006 - 2:24 PM
fastcelica20 good news and bad news. i fixed it but now the int... May 7, 2006 - 9:59 PM
Batman722 make sure the dimmer switch is plugged in properly... May 7, 2006 - 10:56 PM
fastcelica20 QUOTE(Batman722 @ May 7, 2006 - 10:5... May 8, 2006 - 8:10 AM
fastcelica20 mornin' bump
no one knows? May 9, 2006 - 11:42 AM
Batman722 sorry, the dimmer switch is located to the left of... May 9, 2006 - 12:39 PM
fastcelica20 tried that didn't work. could it be my fuse th... May 9, 2006 - 3:26 PM
massbrandon QUOTE(fastcelica20 @ May 9, 2006 - 4... May 9, 2006 - 4:28 PM
fastcelica20 well i shouldn't be checking the ones on my ho... May 9, 2006 - 5:28 PM
fastcelica20 ok i found something weird. here are some pics:
... May 9, 2006 - 7:53 PM
TheStreetzKing u check fuses?? May 9, 2006 - 8:54 PM
fastcelica20 QUOTE(TheStreetzKing @ May 9, 2006 - 8... May 9, 2006 - 9:03 PM
purplegt4 look for the "DOME" fuse under the hood. May 9, 2006 - 9:13 PM
fastcelica20 i replaced that. here's the problem. i have a ... May 9, 2006 - 9:20 PM
RUNNIN-LOW ok yeah i had that problem once when i install my ... May 10, 2006 - 12:13 AM
fastcelica20 ok i put in my white gauge face back in. the light... May 12, 2006 - 8:45 AM
Zimluura so these white gauge faces are just pieces of plas... May 13, 2006 - 12:56 AM
Niskyspy There is one more thing that might be wrong.
Check... May 13, 2006 - 12:56 PM
fastcelica20 QUOTE(Zimluura @ May 13, 2006 - 12:5... May 14, 2006 - 10:54 AM
Zimluura did the climate control and stuff work before you ... May 16, 2006 - 2:34 AM
fastcelica20 QUOTE(Zimluura @ May 16, 2006 - 2:34... May 17, 2006 - 7:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:35 AM |
