> Blacktop Swap question, Anything else I need?
post May 8, 2006 - 1:04 PM
John93GT
Joined Dec 25, '05
From Gainesville, FL
I found an engine set online that comes with the Engine, 5sp tranny, ECU, uncut wiring harness, ignitor, distributer, alternator, starter, A/C Compressor, and power steering pump. Aside from a new Clutch/Flywheel, am I missing anything necessary for the swap?
post May 14, 2006 - 4:26 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
4AGE blacktop, right?
That's everything you need, of course the wiring needs to be done, and then you need to figure out power steering, coolant, a/c lines, and exhaust of course.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 14, 2006 - 5:16 PM
jsnole
Joined Mar 31, '06
From Jacksonville, Fl.
What will be the horsepower with this new motor?
post May 14, 2006 - 5:18 PM
Dr_Tweak
Joined Mar 31, '04
The blacktop is rated at 170hp.
-Doc
post May 16, 2006 - 2:05 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
QUOTE(Dr_Tweak @ May 14, 2006 - 4:26 PM) [snapback]433936[/snapback]
-Doc
Wouldn't you need to figure out the same things for the slivertop?
post May 16, 2006 - 2:07 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE(Drew-887 @ May 16, 2006 - 3:05 PM) [snapback]434643[/snapback]
-Doc
u need to figure out each of those for every motor
Kawi Love
post May 16, 2006 - 2:56 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
QUOTE(Dr_Tweak @ May 14, 2006 - 10:18 PM) [snapback]433961[/snapback]
-Doc
165 hp (123 kW)
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post May 16, 2006 - 3:13 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
If you got problems with the blacktop wiring into your celi. Ask Dr. Tweak for help or ask him if he could do it for you. He's good at that because he helped me troubleshoot alot of my problems when it came to my silvertop. biggrin.gif
post May 16, 2006 - 7:22 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
if only dr tweak lived in south cali. life would be so much easier.
This post has been edited by j0e_p3t: May 16, 2006 - 7:22 PM
Lo-Fi Version Time is now: September 17th, 2026 - 12:09 AM
