> ST205 Motor into '90 Camry, Progress w/ Pics!
post May 8, 2006 - 4:43 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Hey guys,
Now that my project is getting close to completion, I figured it would be a good time to post a few teaser pics. The final product is going to be a 3rd gen 3s-gte from an ST205 (JDM '95 Celica GT4) with an E153 tranny and KAAZ LSD.
Picture of the GT4 clip before I bought it:
ST205 AWIC heat exchanger + tranny cooler:
Now you see it, now you don't:
I had to use a smaller water pump for the intercooler:
The motor is buttoned back up after a new timing belt, water pump and seals all around:
Motor going back together
V6 Camry rear disk brakes:
I'm currently waiting on my tranny (LSD install in an E153) and the bracket to hold the e-series tranny axles to the block. Wiring is done (except for the A/C wiring) and ready to plug in. After I get those parts, its time for the flywheel (Fidanza aluminum) and clutch (SPEC Stage 2), assembly, install, test, troubleshoot then break-in.
Comments and questions are welcomed!
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post May 8, 2006 - 9:39 PM
Xpander
Joined Sep 5, '02
From Winter Haven, FL
Great Job Charlie!
Welcome to the 3SGTE Camry club tongue.gif Now all you need is the AWD part.
Are you going to use the ST205 brakes all the way around? You should change the Power Steering High Pressure Line now while you have the engine out, those are prone to leaking and are a pain to change out.
Definitely need to get and Oil Filter Relocation Kit, the stock filter location will make contact with the Sway bar bracket.
Here is a recent picture of my current set up:
Good Luck!
-Colin
post May 8, 2006 - 9:58 PM
Chanh55
Joined Jun 29, '03
One question... why?
This should be in off topic...
post May 8, 2006 - 11:30 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
QUOTE(Xpander @ May 8, 2006 - 9:39 PM) [snapback]431791[/snapback]
Great Job Charlie!
Good Luck!
-Colin
why not put that setup in your celi??
" i don't work for toyota, i work for my toyota. "
post May 8, 2006 - 11:42 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
cuz in AWD camry its super sleeper.
Team 6gc 2005
post May 9, 2006 - 12:22 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
bboy
post May 9, 2006 - 12:48 AM
urbandork
Joined Jul 16, '04
From Los Angeles
looking good man.
btw im still getting the reciept thingy together.
hows that oil filter thing doing u?
post May 9, 2006 - 11:38 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE(Drocay @ May 9, 2006 - 12:42 AM) [snapback]431825[/snapback]
I <3 AWD turbo lol
Kawi Love
post May 9, 2006 - 11:42 AM
Xpander
Joined Sep 5, '02
Only reason I didn't swap it into the Celica is because I had already done the 4AGE 20v swap. Besides Alltrac Camry + ST205 Celica = Soooo much fun. The look on peoples faces is priceless. I'll be getting some video of the car in action soon, random peoples expressions, and possibly on the dyno.
We should compare dyno numbers when you get it running Charlie biggrin.gif . Hopefully I'll have some HP/TQ numbers myself by then.
-Colin
post May 9, 2006 - 1:14 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Question why: I build sleepers. I don't build cars for show. I build them to drive them and enjoy them. My original plan was a 2nd gen 3s-gte, but the clip was such a good deal I went for it... When this is done, I'll have a 250whp car with 4 doors that gets 30mpg and won't attract any attention from cops with less than with about $6k invested (including the car!!). What more can you want?
I have the rear diff 'n stuff from the clip also, but I will be waiting to find an all-trac Camry to do that swap... There is no reason to do a custom AWD setup when there is a stock version out there. If I find a good all-trac Camry, everything is getting swapped over. It should pretty much be a plug-n-play thing to swap my current setup into an all-trac.
Craig, I'll let you know how the oil filter relocation works out once I have the motor in the car. smile.gif
-Charlie
PS. My PS high pressure line, steering rack, tie rod ends, wheel bearings, axles, bushings, springs, struts, swaybars and many other things are new or very recently replaced... pretty much everything the car is new (except for the primer gray outside!)
post May 9, 2006 - 3:02 PM
jdg371
Joined Jun 14, '05
SWEET!!! Turbo Camry!!!
I got some questions.. How does the body hold? I mean with all the power its pushing now is there a problem on a twisting frame or any of that sort?
Any plans on upgrading the turbo or any component to get more hp/tq out?
What rims/tires are you going to run??
MORE PICS!!!!
This post has been edited by jdg371: May 9, 2006 - 3:13 PM
post May 10, 2006 - 12:48 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
bowdown.gif bowdown.gif bowdown.gif bowdown.gif bowdown.gif bowdown.gif bowdown.gif bowdown.gif
CHEERS TO INGENUITY!!!
This post has been edited by easternpiro1: May 10, 2006 - 12:49 PM
post May 10, 2006 - 4:38 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(jdg371 @ May 9, 2006 - 1:02 PM) [snapback]432018[/snapback]
MORE PICS!!!!
The body is doing just fine. Even with 320k miles on it! tongue.gif The frame and all that will be fine with the power, but I already upgraded every suspension component I could get my hands on (I have every aftermarket suspension part available for the car, pretty much). I will be interested to see how the front suspension handles 250hp+, since it is not a normal lower a-arm / machpherson setup. It uses a single lower lateral link with the front swaybar running a big loop to the front of the car acting as a drag link at the same time. The only advantage I see is weight/simplicity and I now have the ability to adjust caster...
Before the motor swap, I had a simple turbo kit on the car that was probably pushing 160hp or so at the flywheel... Faster than any stock V6 Camry I had ever been in, but nothing special (heh, not compared to my WRX, at least!).
My plan for the motor is this: Boost controller (12lbs or so 'low' and 16lbs 'high'), 3" mandrel exhaust (the car already has 2.5" mandrel bent exhaust, good enough for now) and that's it. I want to drive this car at least 30k miles as is with no major work other than oil changes.
I currently have 7th gen Celica GTS wheels with 205/50-16 Falken GRB451 tires. Those wheels won't fit the ST205 brakes I have (front AND rear!), but I might just sell those brakes and not worry about the hassle of upgrading (everything would have to be customized to fit...)
-Charlie
PS. I'll have more pics when its all done!
post May 10, 2006 - 8:49 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
ooh nice project! so few 3s camrys out there they make awesome sleepers
a gen3 camry was my very first car (handed to me by my dad)... camrys'll always have a place in my heart. hah
i always dreamt of turboing or swapping a 3s into my cam... but in the end i got rid of it and now i have my celi
06 Civic EX
My For Sale Thread
post May 11, 2006 - 8:00 PM
Cutrara
Joined May 6, '05
From PA
You sneaky SOB... race for some cash, man!
Sweet sleeper!
post May 12, 2006 - 12:37 AM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
lol go go 3sgte!
go show them srt-4 foo's u mean business lol
"what happened, that camry whooped ur srt-4"
lol i can hear it already...
Is this good enuff 4 ya? :D
post May 12, 2006 - 10:28 AM
dustinkemp
Joined Sep 23, '04
From Ohio
thats a sweet ride, i wanna see the finished pics of it
post May 12, 2006 - 10:57 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
i started thinking about (almost) this very thing. my boss just bought a camry with a 2.2l in it and i was like HEY what if one of the 5sfe legends on here got ahold of it and slapped on a turbo setup?? ultimate sleeper/kid hauler...MUCH
Coming in 2010
post May 12, 2006 - 11:07 AM
very awesome swap!
post May 12, 2006 - 4:24 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(lagos @ May 12, 2006 - 9:07 AM) [snapback]433268[/snapback]
very awesome swap!
Lo-Fi Version Time is now: June 22nd, 2026 - 11:49 PM
