May 8, 2006 - 5:32 PM
Enthusiast ![]() ![]() Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) |
Where is the EA1 plug located in the engine bay? Cuz i havent found it yet
Bigal PS thanks in advance for the help -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
May 8, 2006 - 7:17 PM
its under the square part of the fuse box in the engine bay
May 8, 2006 - 8:36 PM
Its the big one in the fuse box. Remove the fuse box and its the one that plugs into the bottom.
May 9, 2006 - 1:07 AM
The main relay box that is on the driver side of the engine bay?
(like this relay box) ( or this one)
May 9, 2006 - 6:22 AM
the first pic under the section that says "relay& fuse"
once you remove the cover and have a look, youll see that the "square" section of the fusebox is removeable, once you lift it, EA1 is under that. -------------------- Former Team 5SFTE pro member ;)
May 9, 2006 - 8:48 AM
Enthusiast ![]() ![]() Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) |
As Pressure2 says, it's under your main fuse box in the engine bay. The fuse box has plastic clips on each side that lock the top and bottom sections together. Once you unlock these clips(not hard) the top of the outer casing will lift off. You will now have access to the fusebox wiring.
-------------------- ![]() 1994 GT-S (BEAMS) swap complete |
Oct 5, 2009 - 3:13 PM
wow, bringing from the dead, but could not find a pic
which one is it Im assuming is this one right? ![]() or this one
Oct 5, 2009 - 4:15 PM
wow, bringing from the dead, but could not find a pic which one is it Im assuming is this one right? ![]() or this one ![]() the first pic. -------------------- Former Team 5SFTE pro member ;)
Oct 5, 2009 - 6:35 PM
thanks
| Lo-Fi Version | Time is now: July 7th, 2026 - 4:27 PM |
