> do i need an allignment kit?
post May 10, 2006 - 10:44 AM
hashmaster52
Joined Dec 3, '05
From San Jose, CA
hey im getting some kyb's and either some tein s-tech springs or eibach sportlines. i saw on tirerack.com that it said an allignment kit was strogly recommended. do i really need one?
post May 10, 2006 - 10:54 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(hashmaster52 @ May 10, 2006 - 12:44 PM) [snapback]432381[/snapback]
I recommend them forthe sake of tire life
-Rémy
02 SiR, 08 250R
post May 10, 2006 - 11:11 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
ill second that...i got mine installed, they put them in the wrong spot, but the guy at the alingment place moved them for me...it just makes life easier. And its oly like $60 worth of parts.....saves time, money, and headaches later.
Kawi Love
post May 10, 2006 - 12:09 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
YES!.. I would say get one. I have kyb-gr-2's and eibach sportlines and after a year and half of driving i need new wheels. I dont drive much 15k miles.
Also make sure they send you 15 mm for the front and rear. They sent me 17mm for the front and there info is wrong.
I was sent the 17mm and after them callign back and forth (they kept calling me, thats how helpfull they were) We both figured out i needed 15mm for the front as well as the rear.
post May 10, 2006 - 6:10 PM
hashmaster52
Joined Dec 3, '05
From San Jose, CA
thx guys
post May 10, 2006 - 7:58 PM
Celi94bk
Joined Apr 5, '06
From PITTSBURGH, PA
So thats why My tires wear so uneven ....HMM can you put this on after you had them installed. Mine were installed like 3 years ago, I go through tires like crazy.
How much are they and can you provide me a link ..
Thanks
This post has been edited by Celi94bk: May 10, 2006 - 7:58 PM
post May 11, 2006 - 7:56 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(Celi94bk @ May 10, 2006 - 9:58 PM) [snapback]432639[/snapback]
Thanks
www.tirerack.com
You only need 2 bolts, for the rear. The front camber is negligeable.
-Rémy
02 SiR, 08 250R
post May 11, 2006 - 8:17 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(Rayme @ May 11, 2006 - 8:56 PM) [snapback]433059[/snapback]
Thanks
www.tirerack.com
You are missinformed. The Front are Just as or more important.
Get front and rear. You should be fine withy the 1 degree, which is a top bolt only for each corner. If you get anything lower than 1.5" get 2 degree, which should be a top and bottom bolt.
post May 12, 2006 - 7:10 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(Digndoug @ May 11, 2006 - 10:17 PM) [snapback]433070[/snapback]
Thanks
www.tirerack.com
I speak from experience, my 90 celica didn't need any front camber adjustmen after the lowering. The rear was "so bad" you could see it with the naked eye. My front tire wear was normal after. I'd never think a 6th gen is that different.
-Rémy
02 SiR, 08 250R
Lo-Fi Version Time is now: June 9th, 2026 - 5:16 PM
