> 7afte TMIC?, Is it possible?
post May 10, 2006 - 11:40 PM
Projektminisupra
Joined Apr 6, '06
From Willington, CT
is a top mount intercooler even capable of being used on a 7afte... i have a 7afe and plan on beginning to buy all necessary items for turbo instalation and was wondering if it would even work for this engine and where i can get one if it could.
(i dont plan on running alot of boost.. at all. 10 psi tops so max hp that i can reach isnt really an issue)
Mini Supra... in need of mini boost.
post May 10, 2006 - 11:46 PM
the top mount is a good intercooler.... but you cant mount it on top like the 3sgte has. you can use it, but have to figure out a way to mount it up front or off the the side.
post May 10, 2006 - 11:53 PM
Projektminisupra
Joined Apr 6, '06
From Willington, CT
QUOTE(lagos @ May 10, 2006 - 11:46 PM) [snapback]432718[/snapback]
I figured... it looks like there isnt much above the engien room for teh 7afe... it was just a thought. thanx.
post Jun 9, 2006 - 9:56 AM
akiyama
Joined Dec 19, '05
my 7afte is TMIC. it uses the bracket from the 4efte. but you cant really put a big intercooler if its top mount. also you always need to remove the intercooler when changing sparkplugs.
post Jun 9, 2006 - 10:33 AM
BlackSTX
Joined May 17, '03
From Florence, KY
QUOTE(akiyama @ Jun 9, 2006 - 10:56 AM) [snapback]442921[/snapback]
Pictures please.
post Jun 9, 2006 - 11:15 AM
with a TMIC, if your not directing cold, outside air over it somehow, it is pretty much usless.
i cant see why youd even bother with one, unless its a W2A top mount, with the heat exchanger mounted up front, like the 185RC, or the 205
post Jun 9, 2006 - 11:30 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
What I would do is relocate the battery and then use a W2A intercooler on the right side of the motor. For space reasons I would find a smaller EBay unit like a spearco or turbonetics design, then youre good to go.
Then all you would need is a resivoir for the coolant/water mixture, a pump to keep it flowing, and perhaps a heat exchanger to cool off the fluid to keep intercooler temps down. That would make for a nice setup with very little lag and good cooling properties.
EDIT- Manny beat me to the punch....doh.
This post has been edited by Silver94CelicaOwner: Jun 9, 2006 - 11:31 AM
Lo-Fi Version Time is now: September 14th, 2026 - 3:57 PM
