May 13, 2006 - 1:04 AM
Enthusiast ![]() ![]() Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) |
Today, I took out my Fidanza flywheel and my Exedy OEM replacement pressure plate to look at them. I wanted to see how the pressure plate would look mounted on the flywheel, so I tried to fit the studs on the flywheel through the holes on the pressure plate. I tried many times and rotated the pressure plate but the two parts just won't go together. The holes and the studs are off by just a hair, so I just wanted to know if this is a big problem and I should be worried or if it is a minor problem and it can be easily fixed. Thanks
May 13, 2006 - 11:22 AM
QUOTE(TRD-ST204 @ May 13, 2006 - 2:04 AM) [snapback]433479[/snapback] Today, I took out my Fidanza flywheel and my Exedy OEM replacement pressure plate to look at them. I wanted to see how the pressure plate would look mounted on the flywheel, so I tried to fit the studs on the flywheel through the holes on the pressure plate. I tried many times and rotated the pressure plate but the two parts just won't go together. The holes and the studs are off by just a hair, so I just wanted to know if this is a big problem and I should be worried or if it is a minor problem and it can be easily fixed. Thanks sounds like you may have gotten the wrong parts somewhere along the line... -------------------- Former Team 5SFTE pro member ;)
May 15, 2006 - 6:41 PM
QUOTE sounds like you may have gotten the wrong parts somewhere along the line... No, I went back to check the part numbers for both parts and made sure it was for a 2.2L 5SFE. The thing is that they aren't off by even a millimeter, just by a HAIR! So can the pressure plate hole be sanded just a tiny bit or will that probably cause a problem. |
May 15, 2006 - 6:54 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
If the holes aren't lined up correctly, then there is a big chance of excess vibration caused by the plate not running 'true'. This can result in excessive vibration which is not good.
The question is - which is wrong? The flywheel or the plate? I would take a trip to my local spares shop and see if they have another plate or flywheel to try and determine which one is incorrect. Once you have determined that, send the incorrectly holed item back for a replacement. At least then, you won't run into any issues. Some people may say just redrill the plate, but I wouldn't, just to be on the safe side. Especially if the flywheel has been drilled incorrectly. HTH Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
May 16, 2006 - 6:21 PM
QUOTE(GT4WRC @ May 15, 2006 - 11:54 PM) [snapback]434375[/snapback] If the holes aren't lined up correctly, then there is a big chance of excess vibration caused by the plate not running 'true'. This can result in excessive vibration which is not good. The question is - which is wrong? The flywheel or the plate? I would take a trip to my local spares shop and see if they have another plate or flywheel to try and determine which one is incorrect. Once you have determined that, send the incorrectly holed item back for a replacement. At least then, you won't run into any issues. Some people may say just redrill the plate, but I wouldn't, just to be on the safe side. Especially if the flywheel has been drilled incorrectly. HTH Gary Thanks, thats is what I was going to do, but now I have to find time to do it. |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 5:48 AM |
