> Can't put rotor back after new e-brake shoes, grrr
post May 13, 2006 - 7:45 PM
Rayme
Joined Feb 18, '06
From NB, Canada
mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif <
the freakin' rotor won't get in place after I replaced the shoes of the parking brake on the back wheels.
I loosened teh cable at the lever and nothing works
My car is pwning me!!! help!
-Rémy
02 SiR, 08 250R
Replies (1 - 3)
post May 13, 2006 - 9:01 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
QUOTE(Rayme @ May 13, 2006 - 7:45 PM) [snapback]433696[/snapback]
It's not a simple case of 'loosening' the cable I'm afraid. You'll need to adjust the hub mechanism. Get yourself a manual - or, if you don't know what you are doing, get an expert to show you. Brakes are not something that you wnat to get wrong.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post May 13, 2006 - 9:13 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I did the other side, and there don't seem to be anything else to adjust, I have both a hayne's and the the toyota manual on brakes. No help from there.
The only thing adjustable in there is the adjuster itself, which is already to the "smallest" setting for new pads.
-Rémy
02 SiR, 08 250R
post May 15, 2006 - 4:01 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
If the adjuster located at the bottom of each pair of brake shoes is at it's smallest setting and the hand brake is all the way down you either have something installed wrong or you have the wrong brake shoes.
It's all illustrated right here:
http://www.celicatech.com/imagearchive/bgb...ke%20system.pdf
Lo-Fi Version Time is now: August 31st, 2026 - 3:46 AM
